2013 650 Brute Force SRA - MudInMyBlood Forums
post #1 of 5 Old 03-22-2017, 02:48 PM Thread Starter
Hey guys i have a 2013 650 Brute Force SRA. Was looking to get some new rims and tires but running into issues and any help would be greatly appreciated.
Factory Specs from what i find are 4/137 and 12x7 Rims.
Now i purchased the bike with 14x9 front and 14x11 rear rims.
Im looking to purchase possibly some 12x7 rims for front and rear for mud BUT according to the seller since my rear is SRA it will require spacers so the front or matches the rear. Was wondering if someone can point me in the direction of rims or offset so they can match WITHOUT spacers? I hope that make sense and takes in advance..
megabitez is offline
post #2 of 5 Old 03-22-2017, 03:27 PM
Well, we need to know a couple of things. One, as there is no such thing as 14x9 or 14x11 wheels (tires-yes), and no SRA or IRS came with 14" wheels, we need to know what it had to start with. Standard ATV/UTV wheels can be up to 8"s wide and come in either 12" or 14"s. Now the offsets can be many and you are right in that the SRA has a different offset then any other. The rear axle is shorter or narrower then the front and as such you will have an offset that has it's first number lower then the second..but only for the back. For example...and this is example only- if you were going for a 7" wide wheel, for the back you would be looking at something like a 2+5 or a 3+4 and for the front you would be looking for more of a standard offset like 5+2, 4+3, 4+4...ect. Also keep in mind in some cases struts on some SRAs limit the inward offset. Your task is to end up with the same outward distance on both front and back, but to know that you need to know what it came with or know someone that has done it correctly. IRSs are easy as the front and back are the same. You might want to post this question on Kawieriders. There are a lot more SRAs there.
post #3 of 5 Old 03-22-2017, 03:52 PM Thread Starter
Awesome thank so much and i think i understand.
It came with MOOSE wheels and does are the spec it says on it...
But thank you so much i believe it makes alittle more sense.
A buddy mentioned factory is 4+3 front and 3+5 Rear so im guessing that means the back will sit out a inch more? i really appreciate your help thanks so much
post #4 of 5 Old 03-23-2017, 09:03 AM
If he was using 4 IRS rims (4 rims all with the same offset, for IRS machine) then you would need spacers for the rear, to get them out to the same width as the front. That's probably what he meant by needing spacers.
If you call MudThrowers, and tell them what bike you have, they can direct you with what offset wheels will be needed. They are very knowledgeable. Especially when it comes to brutes.
post #5 of 5 Old 03-23-2017, 01:56 PM
Discount Tire's Avatar
For your Kawasaki Brute Force with a SRA you will want to go with a 12x7 5+2 wheel for the front and 2+5 for the rear to be spaced out correctly without having to use spacers.
We have a couple of Raceline wheels that would work for you:
Raceline Wheels | Discount Tire Direct
Please let us know if we can help.
Low Prices! More Choices! Trusted Experts!
At The Store: www.discounttire.com
To Your Door: www.discounttiredirect.com
Sales and Technical: 1.888.459.4080
Found a Lower Delivered Price?
Need Tires for Your Camper or Trailer?
Useful Links:
Shop ATV/ UTV Tires
Shop ATV/ UTV Wheels
Current Promotions
Discount Tire is offline
06 brute force no power Dasilva Kawasaki 4 12-17-2018 09:32 AM
Need help with my brute force 750!! Walker12 Kawasaki 4 01-04-2018 06:38 PM
Brute Force rear end trouble zromell7 Kawasaki 1 01-15-2017 12:55 PM
08 brute force 750 help needed! Kawi gang Kawasaki 14 02-27-2016 07:29 AM
