Rim Offset Information (How to determin) - MudInMyBlood Forums
post #1 of 25 Old 01-22-2010, 08:34 AM Thread Starter
  • Wheel Offset: Distance between wheel mounting surface where bolted to hub of drum and centerline of rim. Determines vehicles “track” or distance between tires on each axle. Keep the wheel offsets as close to original as possible to avoid steering difficulties or wheel bearing fatigue.
  • Spacing: The first number is the inside spacing (from the back of the rim to the the hub) the second number is the front spacing (from the front of the rim to the the hub). So this would be a 7" wide rim, with 5" from the back of the rim to the hub and 2" from the front of the rim to the hub. If you buy an 8" wide rim this number would most likely change to 5/3 or 5+3 If you wanted WIDE or SRA rims, then the numbers would be roughly reversed, like 3/5 or 3+5 etc... Some 7" wheels might have the offest of 4/3 o 4+3. Instead of 5/2. this is going to make your wheels stick out 1" farther, but should still work fine in the application's of IRS machines without sticking way out from under the fender, or being to wide on trails.
  • The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The photo below shows three wheels with 2",3", & 4" backspace.
post #2 of 25 Old 02-17-2011, 12:56 PM
post #3 of 25 Old 02-22-2011, 05:25 PM
All i ride is Kawi's Avatar
Hey i got a 08 brute 750 i have 28'' maxxis zillas and i mounted them onto my OEM rims when i turn they rub a little bit and some times the back one rubs on the gas tank guard. instead of buying wheel spacers i heard if i buy a aftermarket rim with a certain offset this will eliminate the problem? if so what offset do i get?
08 brute force 750 (sold)
1995 Polaris magnum 425 snorkeled, (tires and paddles soon to come)
All i ride is Kawi is offline
post #4 of 25 Old 02-22-2011, 05:38 PM
Brute650i's Avatar
yes if you buy IRS offset rims 5+2 then it will cure the rubbing. The stock rims are more like a 6+1
2011 Polaris Ranger XP800
2005 Ford Crew Cab F-250
Need Eagle Eye HID's, KUJO A-arm Bushings, MSA Rims, EFX tires, Highlifter Products, ITP Rims, OEM Parts contact me @ [email protected] or B&Cracing-Home
MIMB Members Map
Brute650i is offline
post #5 of 25 Old 02-22-2011, 05:40 PM
The stock off sets are 5.5+1.5 if i get a 4+3 that should make it more wider right?
post #6 of 25 Old 02-22-2011, 05:43 PM
Brute650i's Avatar
yes it will be wider see 1st two post to see why, but a 5+2 is plenty for any width tire unless you just want to go wider or thats all thats offered
MIMB Members Map
post #7 of 25 Old 02-22-2011, 08:09 PM
robisra's Avatar
Send a message via Yahoo to robisra
Check out the pics in this post for a comparison of 5+2 AND 2+5 offset wheels on the brute. The 2+5 (wide stance) do still scrub slightly with 29.5 laws at full lock, but after following the howto remold the inner fenders, it doesn't scrub.
5+2 pics (aka irs wheels)
https://www.mudinmyblood.net/forum/sh...6&postcount=13
2+5 (aka deep dish, sra wheels, wide stance)
https://www.mudinmyblood.net/forum/sh...7&postcount=14
MINE 09 BRUTE 750i
Xtreme 2" Lift, SS112 2+5 offset, High Lifter Springs, 29.5 Laws skinny/wides, HMF Swamp Series w/Snorkel, Viper MX 5000 with Synthetic Line, Radiator Relocate\Water Temp Gage, MIMB snorkels - 3" Center Air Intake, PC5 / Dyna DFS2-20 / DiamondG Module, Red Sec/Almond Pri/56g weights/EPI Belt
HERS 2000 Grizzly 600
MudLites, Warn 2500 Winch
Son's 2011 Chinese 125cc
robisra is offline
post #8 of 25 Old 11-28-2012, 07:09 PM
Here's a pic of my 05 750 with 8" x 14" ITP wheels 26 x 9 front/26 x 11 rear Bounty Hunter tires - since they're 8" rims,I believe these would be a 2 + 6 backspacing.
ID:	12643   Click image for larger version
ID:	12644   Click image for larger version
ID:	12645   Click image for larger version
post #9 of 25 Old 08-19-2013, 05:44 PM
jpence's Avatar
Images: 10
are some 14x6 wheels too narrow for some 31-9.5-14 laws
08 750 brute
31 skinny wide laws Ss 112
Hmf swamp series. PCV k&n
custom rad relocate kit snorkels
warn winch
Kujo bushings rdc lift rhino front axle
teyrex belt
Almond primary Red secondary 56g weights
jpence is offline
post #10 of 25 Old 08-19-2013, 08:02 PM
z24guy's Avatar
All 14x6" wheels should be the same width, 6". That's why they're 6" wide. If it were narrower it would be say 5.5" or if it were wider it would commonly be 7" wide.
So what are you trying to ask?
z24guy is offline
post #11 of 25 Old 08-19-2013, 08:34 PM
jpence's Avatar
Images: 10
well thats exactly what im askin. are they too narrow for the tires? do i need a 14x7 or 14x8 instead? or will the 14x6 work?
08 750 brute
warn winch
teyrex belt
jpence is offline
post #12 of 25 Old 08-20-2013, 10:50 AM
2010Bruterider's Avatar
Images: 29
Send a message via AIM to 2010Bruterider
They won't be too narrow. What you have to worry about is getting the wheels too wide. If the rim is too wide, it will stick out past the edge of the tire. Making the bead hit every rut first before the tire hits it. Constant leaks at the bead. Get no wider than 7" rims or you'll have issues. A 6" rim will be fine.
2010 Brute 750. 29.5 OG s/w laws, VFJ stage 3, Kujo uppers, ASR lowers, rmax manual 4x4 (love it), full HMF exhaust w/snorkle, ODI Rogue grips, Viper 4500 winch, 55w HIDs, ASR tie rods, Gorilla axles, RDC 2" lift, MSD, MIMB 3" center snorkel and MIMB rad relocate.
2010Bruterider is offline
post #13 of 25 Old 08-20-2013, 12:29 PM
jpence's Avatar
Images: 10
thanks alot thats exactly what i needed to know
08 750 brute
warn winch
teyrex belt
jpence is offline
post #14 of 25 Old 10-19-2013, 01:05 PM
mjn
mjn's Avatar
has anyone tried the STI C7 wheels on the Brute?
12" Kaw Brute Force C7 Deep Dish 2 5 Offset Aluminum ATV Wheels New Set 4 | eBay
These are 12X7, have a 2+5 offset, and say they are 2.5" wider per corner.. 5" wider track all around.
How much extra stress would these put on the wheel bearings??
15 Yamaha Viking SE
05 Suzuki Hayabusa
02 Honda Rancher (8000+ miles)
81 Yamaha Seca 550
78 Honda Hawk
69 Honda Z50A
mjn is offline
post #15 of 25 Old 10-19-2013, 02:42 PM
2+5 are for SRAs not IRSs. They would play hell with bearings,ball joints and knuckles. If you have an IRS, you want the first number higher or the same as the second number. Look for 5+2,4+3,4+2, 5+3 or 4+4, 3.5+3.5.
Helpful Information phreebsd Mud Pit 13 04-25-2012 09:53 PM
Can Am information link mrkd1 Can-Am/BRP 3 11-07-2009 08:33 PM
