The proper way to measure a tire. - MudInMyBlood Forums
post #1 of 10 Old 03-25-2010, 07:27 AM Thread Starter
Exclamation The proper way to measure a tire.
Most people measure there atv tires while they are mounted on the bike...I have done the same. I see a lot of folks say I have 28's but they only measure 27...Here is the correct way to measure atv tires. This was posted by Maxxis concerning their Zilla's.
"Inflate the tire to 7psi let set for 24 hours, measure the circumference while the tire is laying on its side and off the ground with no pressure on it...then divide by 3.14. It should be within 0.4 inches of the stated size."
They all have to follow this procedure outlined by the tire & rim association. I hope this helps answer a lot of the your all's questions concerning tire size. There is also another way to measure as well. Put 7psi in the the tire "Unmounted" Wait 24 hours then take one of those tape's that they measure your head size with...the ones that are flexible. Measure from top to bottom and follow the curvature of the tire. That should be within a close true measurement of that tire as well. I have done this with my tires and they are almost spot on.
Thanks, Bootlegger
post #2 of 10 Old 03-25-2010, 08:24 AM
tacoma_2002's Avatar
Send a message via Yahoo to tacoma_2002
Or use a small piece of rope, then measure the rope with a standard tape measure.
'08 Honda 500 Foreman EPS 4x4 (Olive)
'98 Honda 300FW
Lifted, Lawed, Locked
WHY?
CAUSE CHICKS DIG IT!
Murphy's Law: "Anything that can go wrong, Will go wrong"...and If you have as much MUD IN YOUR BLOOD as I do...then you know this law all too well...
tacoma_2002 is offline
post #3 of 10 Old 03-25-2010, 09:00 AM
gpinjason's Avatar
good info
New Family ride: 2013 Ranger 900XP
28" EFX Moto MTC's wrapped around 14" MSA M20 Kores
Custom snorkels - Click here for How To!
Project Mini Crawler: 2001 Yamaha Kodiak 400
Full custom miniature rock crawler.. Coming Soon.
View Thread Here!
gpinjason is offline
post #4 of 10 Old 03-25-2010, 09:00 AM Thread Starter
Originally Posted by gpinjason View Post
good info
Thank You!
post #5 of 10 Old 03-27-2010, 05:44 AM
rhelms's Avatar
I think they must do that for truck tires as well. I measured my 35 Bogger and they only measured 33" with a tape measure across the tire. Thanx Bootlegger I have been wondering if there was a certain way they measured them or if they just lied about the size.
08 Brute 650i
Red on Black
30" Silverbacks
ITP ss108's
2500lb Gorilla Winch
Radiator Relocate
2" xtreme lift
Almond Primary
Green Secondary
rhelms is offline
post #6 of 10 Old 03-27-2010, 07:20 AM Thread Starter
No problem...and yes...truck tires are measured the same way.
post #7 of 10 Old 03-27-2010, 02:59 PM
08GreenBrute's Avatar
cool i didnt now that
2008 Green Brute 750
30" Zillas/SS112's 14"
Xtreme Lift
MSD
Muzzy Pro
VFJ Stage 3
Green/Maroon Springs
HID's 8000k
Temp Gauge
M.I.M.B Snorks
08GreenBrute is offline
post #8 of 10 Old 04-01-2010, 10:43 PM
JHR
JHR's Avatar
thats kind of a pain. Ill just take their word for it. I just dont understand why some tires of different sizes look the same when unmounted and set up side by side. I did this at highlifter a few weeks ago. they had a 30x9 back and a 31x9.5 law both unmounted and i sat them up next to each other and they looked almost exactly the same height. I was like ?
07' Black brute 750i
2" lift w/ 2" pipe lift on front
Penland pro pipe slip on
Dynatec CDI box, temp gauge
Carbs jetted 138f 142r, K&N filter
almond primary, Lime green secondary
31" s/w LAWS 14" ss 112's
K&N filter, monkey back axles
M.I.M.B. snorks, Viper max 4000
Monkey radiator relocate
blue park lights with blue strobes
JHR is offline
post #9 of 10 Old 04-07-2010, 08:08 PM
Lord and Master
Muleskinner's Avatar
Just did this with my wifes bear claws, fronts are 25x8-12 rear are 25x12-10. They have about 50 km on them so wear is not the issue. The fronts measure 25.25" and the rears measure 23.75". Nice to see consistency within the same brand. It sure pulls nice in the mud though-lots of front wheel speed.
Muleskinner is offline
post #10 of 10 Old 03-19-2013, 08:23 PM
Jcooperpcola's Avatar
Good luck measuring an EDL like that.
Sent from my ZTE-Z990 using Tapatalk 2
Jcooperpcola is offline
What's the best all around tire? 1st brute 2010 Tire/Rim 411 189 03-31-2015 09:49 PM
Tire ? 08sportsman Tire/Rim 411 5 02-17-2010 10:01 PM
How Do PitBulls Measure Up? RedneckOfTheWoods Tire/Rim 411 8 02-17-2010 09:12 AM
Tire weight Trapper Tire/Rim 411 4 01-19-2010 08:15 AM
tire upgrade browland Tire/Rim 411 21 11-04-2009 05:35 PM
