pod/wiring problems - MudInMyBlood Forums
post #1 of 3 Old 01-23-2014, 05:08 PM Thread Starter
jonnydz's Avatar
pod/wiring problems
Hi guys I have 2010 mudpro 700. My pod is working intermittently. I have a new motobatt with a full charge. I have also tried resetting by touching the positive and negative leads together. i know this can be A problem with my wiring harness as well. Sometimes it lights up blank and sometimes it works fine and sometimes it flashes efi. The bike runs fine other wise. I have taken it off and there is no corrosion or lose wires. My next step is to test the pod plug I guess to see if it is getting the correct voltage before I buy a new pod. has anyone done this or know which pin gets what voltage?
Jonnydz: 08 King 750
racked and snorked
Coop3
28" ol2's on Diesels
Rhinos
Her Bike: 2010 mudpro 700
28" Ol2
jonnydz is offline
post #2 of 3 Old 01-23-2014, 07:31 PM
J2!
J2!'s Avatar
The Arctic Cat pods are junk, notorious for going out. Mine is an 06' and it's been out since 09'. Some have had problems with the plug on the back but most likely if it's only working sometimes it's probably toast. That's the same way mine started, then it would just bouce around and say I was going 20mph sitting still. THEN it died.. LOL
BAMABOGGERS EXTREME BOG TEAM 06 Arctic Cat AMR 840
Ranger 900 Bud Light Blue / Outkast 5"
J2! is offline
post #3 of 3 Old 07-27-2014, 12:23 AM
I have a 2007 AC700, started out as not starting but spinning over and backfires through throttle body, I used a jumper and pulled codes, none were available, now the pod went out completely and now nothing works but the lights. Any suggestions
moneybags is offline
Fuel pump wiring problems?? Ecm not supplying ground Josh Kawasaki 11 06-17-2013 10:14 PM
wiring diagrams gav09 Trucks 0 10-30-2012 08:34 AM
420 hid wiring redneckrancher420 Honda 0 09-04-2012 06:02 PM
problems with wiring 02KODIAK400 Mud Pit 0 06-29-2012 08:21 PM
hid wiring help BIGPUN Kawasaki 6 02-13-2012 09:19 PM
