2010 brute 750 fi problem - MudInMyBlood Forums
post #1 of 2 Old 05-18-2018, 06:01 PM Thread Starter
I just got a 2010 brute and I thought the fuel pump was bad because it would sputter above 1/4 throttle and the fi light would flash while running so I replaced it with a brand new pump and now it barley runs before it would idle now it just cuts out if you don’t play with the throttle. New to the brute game any ideas?
Braxtonk is offline
post #2 of 2 Old 05-23-2018, 10:54 AM
ian.macmillan's Avatar
Originally Posted by Braxtonk View Post
I just got a 2010 brute and I thought the fuel pump was bad because it would sputter above 1/4 throttle and the fi light would flash while running so I replaced it with a brand new pump and now it barley runs before it would idle now it just cuts out if you donít play with the throttle. New to the brute game any ideas?
First thing I would do is pull the code from the FI light - it would be a good indicator of where to start. You can see how to do that here:
My bike was doing the same thing and clogged injectors ended up being the problem.
2008 Kawasaki Brute Force 750i Fuel Injected
ian.macmillan is offline
2010 Brute Force 750 Spontanious starting RandyTruette Kawasaki 2 02-27-2018 12:53 PM
2010 brute 750 fuel probs? Ckpoorboy Kawasaki 3 01-29-2017 04:56 PM
2010 Kawasaki Brute Force 750 doesn't have full power Broke_Force Kawasaki 7 01-18-2017 06:40 PM
Rebuilt 2010 750 Brute running Hot/Lean davisboy421 Kawasaki 1 07-17-2016 05:36 PM
Brute force HMF problem Candy green Brute Kawasaki 1 05-10-2016 12:28 PM
