2008 Brute Force Popping and Sputtering - MudInMyBlood Forums
post #1 of 10 Old 09-03-2018, 02:35 PM Thread Starter
DanOMite's Avatar
I need some guidance for an issue with my Brute. I've read multiple threads and tried a handful of different things with no success.
Brute info:
2008 Brute Force 750
4372 kms (2716 miles)
311 hours
2" snorkels
Stock exhaust
MSD purchased from VForce John tuned for 2" snorkels & stock exhaust
Catch can mod
Issue:
About 5 months ago the Brute began to pop and sputter from a cold start when starting to ride but it typically goes away after a few minutes, it rarely does this from a cold start. After letting the Brute sit for 20 min It'll start / idle fine but will sputter & pop way worse when I try to ride it. Idle good, 1/3 to 1/2 throttle extreme popping and sputtering, full throttle it'll pop & sputter then take off. When it's popping and sputtering I can hear it from the air box too, it seems to be starved of fuel. This doesn't go away until the Brute sits for extended periods or overnight which tells me it could be related to heat.
What have I tried:
- Fresh gas
- Gas tank checkvalve good, not starving it that way
- Highly suspicious of the fuel pump being an 08 Brute
- Had pump tested at dealership and its pumping 42psi
- Pump screen was dirty and they cleaned it, I thought this was the magic bullet but no
- Throttle positioning sensor checked also by dealer
- I removed MSD and ran stock, problem still exists
- Checked wiring under the seat and fuses
What I suspect:
I suspect the fuel pump could be the culprit seeing how the problem surfaces after the machine reaches running temperatures. The dealer probably ran it for short tests not allowing it to reach operating temperatures. It's still the original fuel pump too. 08s are notorious for having fuel pump issues but I don't want to change it if it could be something else. I'd like to explore all my options before I take the plunge and pay for an overpriced fuel pump.
I love this machine but honestly I feel like pushing it off of a cliff
2008 Brute Force 750i
26" ITP Mud Lite XL
2500lb Warn Winch
VFJ MSD Charge FI
2" Snorkels
Catch Can Mod
DanOMite is offline
post #2 of 10 Old 09-03-2018, 07:00 PM
My first assessment would have been the pump too or fuel-related...especially sense it's an 08. But lets check the valves and the throttle body boots for any issues, then lets check the valve timing and compression. If the compression is low, lets do a leak-down test to find what's bad. While at it lets test the voltage- both static and running and..the coil voltage. Lets not forget those peskie fuse boxes- pull it, flip it over and check all the connections underneath. And if all that is good..check the CPS.
post #3 of 10 Old 09-03-2018, 08:45 PM Thread Starter
DanOMite's Avatar
Thanks NMKawierider, looks like I got some work to do! When I make some progression Iíll update this thread. Many thanks for giving some advise.
26" ITP Mud Lite XL
2500lb Warn Winch
VFJ MSD Charge FI
2" Snorkels
Catch Can Mod
DanOMite is offline
post #4 of 10 Old 09-03-2018, 08:49 PM
Probably something simple..just finding it is the tough part sometimes.
post #5 of 10 Old 09-10-2018, 09:04 PM Thread Starter
DanOMite's Avatar
It’s fixed! I thought I’d post what my issue was to help someone else out. I was trying various things but was making no progression. I took it to the shop and they found the issue. My rear plug was constantly being fouled. After changing the plugs the rear would foul up very quickly, the front was fine. They leaned out the rear cylinder and tested with positive results, the rear was no longer being fouled.
The Brute runs like a champ now. I swear I have more power too!
26" ITP Mud Lite XL
2500lb Warn Winch
VFJ MSD Charge FI
2" Snorkels
Catch Can Mod
DanOMite is offline
post #6 of 10 Old 09-18-2018, 07:26 AM
ian.macmillan's Avatar
"Leaned out adjuster on rear cylinder"? How do you lean out one cylinder on an EFI bike without changing the fuel mapping?
2008 Kawasaki Brute Force 750i Fuel Injected
ian.macmillan is offline
post #7 of 10 Old 09-18-2018, 08:10 AM
Exactly..not possible to lean one cylinder even through re-mapping....unless you have a controller you can do that with. Probably had a bad/leaking injector.
post #8 of 10 Old 09-18-2018, 08:42 PM Thread Starter
DanOMite's Avatar
When I picked up the machine they said there was an adjustment in the throttle body, I want paying too much attention though. Next time I take it to Dr. Kawasaki Iíll ask for more details just out of curiosity.
Cheers!
26" ITP Mud Lite XL
2500lb Warn Winch
VFJ MSD Charge FI
2" Snorkels
Catch Can Mod
DanOMite is offline
post #9 of 10 Old 09-19-2018, 07:40 PM
drewski1126's Avatar
Are they referring to the vacuum synchronization lines. I had to adjust mine after I found the guy before me had installed the rear cam in 180 out and the thing was running on one cylinder. He adjusted it to compensate for this issue. The bike was actually running but not at all powerful
Once I got the cam issues resolved I had to undo his adjustment on that Vacuum sync to get it running good again.
drewski1126 is offline
post #10 of 10 Old 09-20-2018, 10:09 AM Thread Starter
DanOMite's Avatar
Thanks for the details and pic drewski1126!
26" ITP Mud Lite XL
2500lb Warn Winch
VFJ MSD Charge FI
2" Snorkels
Catch Can Mod
DanOMite is offline
