Brute 750 Display Not Working - MudInMyBlood Forums
post #1 of 2 Old 09-25-2018, 07:32 PM Thread Starter
Hello all! I have a 06 Brute 750 that the dash display isn't lighting up on. I have owned this bike for three years and it has worked flawlessly up until yesterday and when I turned the key on it didn't light up. Everything else works on this bike. Still runs great, headlights work, neutral light comes on, reverse light works, it's just the readout. The oil light also will not flash when the key is on and it's not running like it does when the display is working. I have checked for broken wires, bad grounds and found nothing. You can unplug the harness and plug it back in with the key on and sometimes it will start working and will work till you turn the key off and then it will not come back on till you unplug the harness for a couple minutes and plug it back in with the key in the on position. Once you get it working it will stay working till you turn the key off. I cleaned the harness good and put dielectric grease on it and it still does the same thing. I don't have any friends with a Brute that I could try their display on mine to see if that's what it might be. Any ideas? Has anyone had this problem before? This bike has not been in the mud or water. I literally just ride it on trails. I'd appreciate any help at all. Thanks.
thir13en is offline
post #2 of 2 Old 09-27-2018, 07:13 AM
Sounds like the unit itself may be going bad.
2008 Brute Force Popping and Sputtering DanOMite Kawasaki 9 09-20-2018 10:09 AM
Brute force front axle inner splines getting shredded Mooseheadluke Kawasaki 9 05-22-2017 08:30 AM
08 brute force 4wd not working. Jtaylor1979 Kawasaki 4 04-11-2016 10:19 AM
winch and fan stopped working on brute force? help? Bf750 Chad Kawasaki 4 03-02-2016 08:02 PM
08 brute force 750 help needed! Kawi gang Kawasaki 14 02-27-2016 07:29 AM
