07 BF rear drive shaft removal - MudInMyBlood Forums
post #1 of 4 Old 10-27-2018, 11:58 AM Thread Starter
I’ve got an 07 650i. I have a leak on the seal from the drive shaft to the engine. My drive shaft would not compress so I had to unbolt the rear diff to get it out of the engine. Since I’ve got it apart I wanted to replace the seal from the back of the drive shaft to the diff. My protis that the drive shaft won’t pull out of the diff. Should it just yank out or is there some type of retainer holding it in?
mrvmax is offline
post #2 of 4 Old 10-27-2018, 12:12 PM Thread Starter
BTW, the drive shaft was full of mud and that’s why it didn’t compress
mrvmax is offline
post #3 of 4 Old 10-27-2018, 03:54 PM
The yokes on either end are just on splines. So is the slide section with a spring pushing either end apart and onto the other splines. Soak it a while with some WD or PB. Then start tapping around and away. It should slide off. Clean it well and grease it...all of them...before reinstalling. Pay attention to how the yokes are positioned on either end when taking the center apart. Has to go back the same way.
post #4 of 4 Old 10-27-2018, 04:34 PM Thread Starter
Thanks
mrvmax is offline
???? 08 750 rear cylinder not firing ???? drewski1126 Kawasaki 7 01-29-2018 06:56 PM
15 BF 750 rear shock size and options trailrabbit Kawasaki 0 04-08-2017 06:49 AM
need the gurus in here, 650 BF losing rear spark after 3 seconds Leer5000 Kawasaki 2 10-12-2016 06:18 AM
07 650 SRA Rear Swing Arm Seal BamaBrute650 Kawasaki 0 02-04-2016 04:40 PM
2005 Brute Force Rear Differential HELP svtcobra43 Kawasaki 7 01-20-2016 03:12 AM
