2012 brute force 750 v-twin won’t start - MudInMyBlood Forums
post #1 of 6 Old 01-27-2019, 04:10 PM Thread Starter
My 2012 brute force won’t start. Was running fine until one day the battery wouldn’t keep charge. I took out the stator to replace it and ended up putting it back in and put it all back together I replaced the rectifyer and now all of the sudden it’s not getting spark anymore it’s been sitting for months. Any ideas?
Dcasto15 is offline
post #2 of 6 Old 01-27-2019, 04:58 PM
Did you test the stator? How about the kill switch? Is the CPS/Pulse coil plugged in?
post #3 of 6 Old 01-27-2019, 05:25 PM Thread Starter
The stator had continuity before I put it back in, the killswitch is off and I’m not 100% what the cps is? And I took the coil off and put the tester on the two metal ends where the plug ins go, and it had continuity. Still no fire
Dcasto15 is offline
post #4 of 6 Old 01-27-2019, 05:26 PM Thread Starter
I also checked the main fuse and all the fuses under the seat and they’re all okay the check engine light is on as well and flickers when trying to electric start
Dcasto15 is offline
post #5 of 6 Old 01-28-2019, 08:13 AM
Originally Posted by Dcasto15 View Post
The stator had continuity before I put it back in, the killswitch is off and Iím not 100% what the cps is? And I took the coil off and put the tester on the two metal ends where the plug ins go, and it had continuity. Still no fire
Check it's position again. The CPS is the separate coil you would have seen in the stator cover with the other set of wires coming through the cover. Re-check your connections.
post #6 of 6 Old 01-28-2019, 11:27 AM Thread Starter
So I checked the cps and it seems to all be connected fine the check engine light is still on and it still seems to not be getting any fire
Dcasto15 is offline
Brute Force 750 2012 Won't Start with VIDEO tamibandy Kawasaki 3 12-13-2018 07:26 AM
cant start brute force mikemorales Kawasaki 2 06-09-2016 11:44 PM
2012 brute force 750 ihdeboy Kawasaki 6 04-18-2016 03:10 PM
2006 Kawasaki Brute Force 650 Difficult to Start Belden22 Kawasaki 4 04-16-2016 01:49 PM
2012 fuel injected Kawasaki brute force 750 Litenyaup For Sale/Trade 6 03-31-2016 08:51 PM
