Brute force 2013 - MudInMyBlood Forums
post #1 of 5 Old 04-06-2019, 07:30 PM Thread Starter
Bforce750i's Avatar
Brute force 2013
This quad has had a leaking left side (sitting on bike) leaking front axle differentail oil seal, im not sure the technical term or reference. Always made oil grayish , been like that for 2 years changed frequently and used Lucas oil stab. Willing to replace both sides since right sode started to leak after last oil change.
My issue and worry is the bearings in the diff, how can i test them? Will i likly be f**ked when i pull the axles out will my rollers fall out?
Will provide more info as necessary, thank you for any info help and tips
Bb
Bforce750i is offline
post #2 of 5 Old 04-06-2019, 07:31 PM Thread Starter
Bforce750i's Avatar
Also wonderig about the "scoring" on the casing side of the diff by the axle,
Bb
post #3 of 5 Old 04-06-2019, 07:39 PM
With water being in there you will have all kinds of damaged parts. You best pull it, lay it out on a table and replace all the parts that have been effected by that. A shop manual will guide you through it. Start by getting a bearing and seal kit. Then see what else it will need. The diff-loc disks will all be shot and some gears as well but you won't know until you get it opened up.
post #4 of 5 Old 04-06-2019, 08:13 PM Thread Starter
Bforce750i's Avatar
**** thats what i thought, i drove it like that for 1000km since i had it, but id hate to have it go or do worse damage , i have a shop i can take it out at ugh sh*t.
Bb
post #5 of 5 Old 04-06-2019, 08:50 PM
a 1000km or 621 miles with water in the lube? Well.. plan on a new diff..might get lucky but plan on the worst and hope for the best...
Rare 08’ Brute Force with 150 miles! What mods would you do? dcraine Kawasaki 6 03-30-2019 08:50 PM
2008 Brute Force Popping and Sputtering DanOMite Kawasaki 9 09-20-2018 11:09 AM
2013 brute force back firring crisscross1 Mud Pit 4 06-30-2017 10:35 PM
2013 650 Brute Force SRA megabitez Tire/Rim 411 4 03-23-2017 02:56 PM
brute force eating belts help ryanharrington827 General Tech. & Audio Info. 6 02-11-2016 06:25 AM
