2014 Brute Force 650i - MudInMyBlood Forums
post #1 of 2 Old 06-30-2019, 11:41 AM Thread Starter
Hi guys so my drain plug was leaking oil after I did an oil change so I put in an oversized plug and a piece of the hole with the threads broke off what do I do?
Mel86 is offline
post #2 of 2 Old 06-30-2019, 12:04 PM
Well, now either you take it to a shop that can weld aluminum and re-drill and tap it,.. or replace the engine case...which means a full rebuild of the engine..about 3,000 dollars plus the cost of the case.
