08 650 no spark - MudInMyBlood Forums
post #1 of 3 Old 01-05-2020, 07:57 PM Thread Starter
Macperform's Avatar
08 650 no spark
I am working on an 08 brute force 650. I have no spark on either cylinder. Using the factory service manual I have found a couple of things:
Primary coil windings read .4 instead of .09-.13 and secondary is 10k instead of 3.8-5.8k
Crankshaft sensor reads 113 instead of 423-517
I find it hard to believe that all three of these went bad at the same time and am leaning towards the sensor. The rollover sensor is good (.74)
I do not have the tester to do the peak coil voltage test as described in the manual
What are your thoughts?
Mark
Macperform is offline
post #2 of 3 Old 01-06-2020, 08:55 AM
Not uncommon for the pulse coil...or CPS to go out on these so I would replace it first. While there make sure the key hasn't sheared on the flywheel.
post #3 of 3 Old 01-07-2020, 06:09 PM
josh13's Avatar
I had a similar issue once before and it was my CDI box had went bad.
2005 brute 650 sra
maroon primary, almond secondary
2" lift 27" swamp lites
moose module
2" snorkels
josh13 is offline
