Largest Tires on a stock Polaris - Page 2 - MudInMyBlood Forums
post #16 of 65 Old 05-18-2011, 08:58 PM
I have 31 laws on my 2011 sports 850 xp. i had to cut the fenders back a tad and there is only rub when the suspension compresses quite a bit.
2011 Popo Sportsman XP 850
- 31" Outlaws
- 3500 Polaris Winch (Don't recommend)
- HMF Swamp Series Exhaust
2010 Honda Rancher 420 - Sold
cwm9805 is offline
post #17 of 65 Old 07-03-2011, 07:26 PM
cookster500's Avatar
i got 26-9-12 and 26-10-12 on my 2000 500. no rubbing.
08 650 H1. snorlked, Dalton clutch kit, stock exhaust mod, 30 in mud lites S/W (for trade with or without rims, wantin 14s) and custom paint
cookster500 is offline
post #18 of 65 Old 10-29-2011, 02:49 AM
26" zillas on 2010 sportsman 500
I'd like to know if there will be any clearance issues if I put 26 9 12's on front and 26 11 12's on rear on my stock rims and stock machine. I'm not doing any mod's in terms of lifting and wheel spacers. Would those tires work??
Rosco1971 is offline
post #19 of 65 Old 10-29-2011, 08:42 AM Thread Starter
Should be just fine.
post #20 of 65 Old 01-11-2012, 02:16 AM
Graysen's Avatar
I have a 99 500 and i put 26" MudWolfs and i was fine in the rear but the front i was subbing the right tie rod end so i got 1" spacers for the fronts it lines the tires up really well the middle of the fronts are right in line with the middle of the backs. i had another problem when i had the front shocks fully compressed it would rub my fender and also my double tubed bumper so i have a 2" lift and now i am far away from it rubbing anything.
99 Polaris Sportsman 500
Remington Special Edition
26" MudWolfs
2" Extreme Lift
UNI Air Filter
2500lb SuperWinch
1" Wheel spacer's
Graysen is offline
post #21 of 65 Old 03-12-2012, 12:16 PM
2000 sportsman 335
wanting to go bigger with my tires was thinking 25 10 12 up front nd 25 12 12 out back will fronts clear?? Mudlite xls are what im looking at
tkohl3 is offline
post #22 of 65 Old 03-13-2012, 07:25 PM Thread Starter
should be fine, the 10's up front might rub the shock depending on how close the mount it.
post #23 of 65 Old 05-03-2012, 09:01 PM
I have a 2009 500 X2 with 26x9x12 and 26x12x12 and had to install 1/4" wheel spacers in the front and reverse my tie rods. Can't go any wider but I could go larger in height.
highmark is offline
post #24 of 65 Old 05-20-2012, 04:59 PM
To reply to myself I just picked up a set of 28x10x12 and 28x12x12 Silverbacks. Got a deal I couldn't pass up. I'll need to either reverse my rims or get 1.5in wheel spacers.
highmark is offline
post #25 of 65 Old 05-23-2012, 11:00 AM
2004 sportsman 500
will 26-9, 26-11 ITP XTR's fit
balski619 is offline
post #26 of 65 Old 05-23-2012, 11:04 AM Thread Starter
yeah they should.
post #27 of 65 Old 06-08-2012, 09:06 AM
I have a 2011 standard rzr and depending on tire used between 27 and 28 will work fine. Now I'm running 30in mud lites with just a 1.75 coil spacer in front and a lil reshaping the floor pan.
Tsmith422 is offline
post #28 of 65 Old 06-24-2012, 09:19 PM
primetime1267's Avatar
On the RZR's you have to watch out for the right rear motor mount.. Almost any wide 12" tire will require some trimming of that mount. On stock rims with aftermarkets wide tires, forget it spacers in the rear are almost recommended as well.... Unless you have the "S" model..
2006 Sportsman 700 EFI---29.5 Outlaws s/s, gorilla axles, QSC clutch kit, 2" lift, snorkeled, Rad relocated
primetime1267 is offline
post #29 of 65 Old 06-25-2012, 12:39 AM
JLOWERY's Avatar
My 2011 850 XP had 29.5 Laws 2's on it with no issues it still had plenty of room.
2012 Polaris 850 XP LE EPS Orange Madness 26" Rip Saws on SIXR's front and rear Polaris bumpers 3.5 winch
2013 Polaris 850 XP LE EPS Sunset Red 26" MOTO MTC's on MSA M15 Crushers
2015 Polaris 1000XP LE EPS Black Metallic all stock for now
2014 Polaris RZR 1K 34 Terms on Black Cores
JLOWERY is offline
post #30 of 65 Old 07-18-2012, 11:21 PM
bruteforce3's Avatar
I just put OL2's on my 550xp and it's about a inch from rubbing. Largest Tires on a stock Polaris-imageuploadedbytapatalk1342671684.581213.jpg
2009 Polaris 550 XP
Snorkeled
29.5 Outlaw 2's
SS 212 Rims
bruteforce3 is offline
Largest Tires on a stock Can-Am Polaris425 Can-Am/BRP 20 07-06-2016 01:01 PM
Largest Tires on a stock (NOT LIFTED) Honda. Polaris425 Honda 102 04-26-2016 03:18 PM
2001 stock Cat 500 largest tire ? smittymv Arctic Cat 4 05-29-2010 01:55 AM
Polaris tires&wheels for sale!!! **SOLD** MUDDIE49 For Sale/Trade 2 04-29-2010 06:59 PM
Tires for Polaris Scrambler 500 Thom Tire/Rim 411 5 01-22-2010 08:12 AM
