2006 eiger 400 - Page 2 - MudInMyBlood Forums
post #16 of 22 Old 03-11-2010, 08:51 PM
cowboy316911's Avatar
any jetting req. after snokin it? And any reason for 1.5" to 2" through the fenders? Wife is trying to follow the brute and im about 8" higher so needless to say I spend alot of time draining her belt, only swamped the carb once....
cowboy316911 is offline
post #17 of 22 Old 11-26-2011, 03:22 PM
Hey guys, trying to bring this back from the dead...after turning my wife's 07 Eiger into a submarine for the second time I have decided to snorkel it. (that is if I can clean all the water out of it..I have changed the oil 6 times and still have some water/milkshake sludge in there...hoping i don't kill a rod or crank bearing) I was curious as to the jet size I would need with 1.5 inch pipe and how did you seal the box? Is there much of a benefit to going with 1.5 over 2" pipe other than size? Thanks for any help!
Uncleford is offline
post #18 of 22 Old 12-20-2011, 04:16 PM
Resident Kitty Expert
greenkitty7's Avatar
with 1.5" you probably wont have to jet. the benefit of going with 2in, is that you get more air.
mo air + mo fuel = mo powa.
TEAM CARNAGE
'12 RZR 800 s, snorks, tunes, and training wheels
growing soon....
06 AC 400, little bit of MTI, ///, OTD customs lovin! - Gone...
SWAMP STARZ
greenkitty7 is offline
post #19 of 22 Old 02-25-2016, 10:27 PM
slinger400's Avatar
nice job swampedeiger looks great
2003 Eiger 400 4x4 Mods done by me:)
2" Lift,Blackwidow Tires,High Flow Air Filter,Custom Fitted Hids headlight, 3000 lbs Winch,Warn front bumper,Custom made Audio Tube,Hand Guards,Custom Made Aluminum Skid Plates,Custom Made Aluminum A Arm Guards Custom Made Headlight Guards,Vinson 500 Aluminum Rims,1.5 inch Wheel Spacers.Custom Made Rear Tail Light Guard,Aftermarket Rear Bumper,Shock Covers,Rear Back Up Light,Custom made Rear Storage Tool Box Lid,Custom Led Lights inside the speedometer housing.Rear Hitch Tow Loop
slinger400 is offline
post #20 of 22 Old 03-23-2016, 09:44 PM
slinger400's Avatar
I am not going to be sinking my wheeler in water or mud but just mainly "going for the look" but it will be sealed if i go to deep but not really wanting to do that'
This is how i snorkeled it.i kept a vacuum hose off a junk vacuum i had an i got the pvc pipe 1 1/2 inch from a mobile trailer that was being scraped i decided today i would try to put it all together. i figured id go ahead an post the pics to show anyone else that might want to do it, i know there is all kinds of way to go about doing this but its what i had an how i did it.
The vacuum hose just so happen to fit pretty tight in the original boot of the air cleaner lid ,So i put some rtv gasket maker around the vacuum hose fitting an shoved it in there an used a different hose clamp to tighten it up.Then added some more rtv around the outside,The pvc part is just stuck in the vacuum hose fitting in the pic. Just to give you guys an idea of what it looks like all together,but i will need to get a rubber coupler that will slide over the pvc an that fitting for easy installment an removal.
ID:	17521   Click image for larger version
ID:	17529   Click image for larger version
ID:	17537   Click image for larger version
ID:	17545   Click image for larger version
post #21 of 22 Old 03-23-2016, 09:59 PM
slinger400's Avatar
i got a bunch more pics but will not work right idk whats going on
post #22 of 22 Old 05-13-2016, 07:04 PM
slinger400's Avatar
2006 Brute 650i kdgncop For Sale/Trade 5 02-16-2010 10:30 AM
2006 Foreman 500 Dustyt07 For Sale/Trade 0 11-23-2009 09:08 PM
Help on 2006 Rubicon Manual Please blazinboys305 Honda 9 11-12-2009 08:30 PM
wtb: eiger plastics boostedagain For Sale/Trade 0 10-28-2009 10:20 PM
2007 eiger manual trans funky when wet cheapthrills Suzuki 6 04-24-2009 08:16 AM
