2005 suzuki eiger 400 4x4 help - MudInMyBlood Forums
post #1 of 26 Old 10-15-2010, 02:20 PM Thread Starter
2002 suzuki eiger 400 4x4 help
Removed from lack of help.....
KILLER_K is offline
post #2 of 26 Old 10-16-2010, 07:00 PM Thread Starter
Any help or info on this issue?
KILLER_K is offline
post #3 of 26 Old 10-16-2010, 08:30 PM
cammobruteforce750's Avatar
so you got wrong #'s from dealer and a part store? stupid question but have you try to order a front seal to see if thats it. ive seen this with trucks. pinion seals front and rear. you will get 2 different part #'s but end up just being the same as front. let me look into this and i will get back with you
Name:	jay jay on atv.jpg
2006 brute force 750 snow cammo. 27" itp's on 14" itp wheels. snorkel kit, k&n airfilter, jet kit, warn 2500 winch, stereo system, 2"lift kit, maroon primary and almond secondary.
cammobruteforce750 is offline
post #4 of 26 Old 10-16-2010, 08:49 PM
i found this site. hope it helps. there is a pic below of a seal kit. click on pic and you will get part#
Please dont post that much info to businesses... - Admin.
post #5 of 26 Old 10-16-2010, 09:22 PM Thread Starter
Yes that is the seal i need. The one the shop gets in doesn't even have the lip around the oil seal. I will just order a set from them as having a extra one will be a good thing also.
Bought this for a fix it up project and just seems every time i do something i get into a problem or something is broke, etc.
Thanks
KILLER_K is offline
post #6 of 26 Old 10-17-2010, 09:22 AM
no problem bro. its a easy fix. lemme know if i can help you anymore. cya
post #7 of 26 Old 10-17-2010, 03:09 PM Thread Starter
I got it broke down and just waiting for the seal. As i wanted to fix it right and not just put any seal in there and try to make it work. But when it rains it pours....
KILLER_K is offline
post #8 of 26 Old 10-17-2010, 05:52 PM
yes it does. ive ran into that before with seal and its a never ending nightmare. let me know how it works out for you
post #9 of 26 Old 10-22-2010, 04:25 PM Thread Starter
Got the seal in today. Cleaned everything up and put the seal in. Changed the oil and oil filter. No leaks so i did a good job it seems.
Now i got a few more issues though. Perhaps simple is the steering. I have perhaps a inch play in the steering. And it is kinda hard to look under and turn the handle bars. What could cause this or is it normal to have a little play in it?
Next would be the clutch. It maybe just me but it seems like it could be slipping perhaps. Though the tires aren't super great on it so it could be spinning also. How is the easiest way to check this?
Thanks
KILLER_K is offline
post #10 of 26 Old 10-22-2010, 05:46 PM
gpinjason's Avatar
for the steering, jack up the front of the bike, then grab one wheel at a time and move it from side to side and up and down... while moving the tire, inspect the tie rod connections at the knuckle and the steering stem, inspect the ball joints (upper and lower on knuckle) and inspect the wheel bearings... do this on both sides... any slack in any of these parts can cause your issue... and if they have slack in any of those parts, then you need to replace because it could be dangerous if they fail while riding...
edit: just realized this was a manual shift... in order to inspect the clutches you will have to open it up and visually look at the wear plates on it... I'm sure there is a specification for minimum thickness and such... will need a service manual, or perhaps you can get lucky and the local dealer will answer that question...
hope that helps!
New Family ride: 2013 Ranger 900XP
28" EFX Moto MTC's wrapped around 14" MSA M20 Kores
Custom snorkels - Click here for How To!
Project Mini Crawler: 2001 Yamaha Kodiak 400
Full custom miniature rock crawler.. Coming Soon.
View Thread Here!
gpinjason is offline
post #11 of 26 Old 10-22-2010, 06:06 PM
good advice gpjason
one thing i did learn was when checking the tie rod ends it was easiest to have one wheel on the ground. JMO
I found a bad steering stem bearing 06 Eiger
06 Eiger 400Auto
K&N w/cover
DynoJet
Warn 3.0ci
HM brush guard
HM stick gaurds
26" Zillas
TJ Sheave mod
HD front axles
Vinson shocks
If you don't stand behind our troops, please feel free to stand in front of them.
Hondaex is offline
post #12 of 26 Old 10-22-2010, 06:43 PM Thread Starter
I think it is probably going to be the front wheel bearings. As i haven't replaced those yet. Redid the whole rear-end, etc on it. So i get to the front next i guess. I will call the suzuki shop and see what they say about the clutch. It would perhaps be easier for someone to ride with me so they could watch it when i take off. If i could just get my dog to talk.....
Thanks
KILLER_K is offline
post #13 of 26 Old 10-23-2010, 06:32 PM Thread Starter
KILLER_K is offline
post #14 of 26 Old 10-24-2010, 04:40 PM Thread Starter
KILLER_K is offline
post #15 of 26 Old 10-25-2010, 04:22 PM Thread Starter
KILLER_K is offline
2006 Suzuki Eiger 450 - Auto (feeler) uppidycon For Sale/Trade 8 10-27-2010 03:46 PM
Eiger 400 A Hondaex Suzuki 7 10-13-2010 07:22 AM
2005 eiger motor crom a zone For Sale/Trade 1 03-15-2010 11:22 PM
Cheap Eiger mod cletus Suzuki 0 02-18-2010 06:05 PM
!!!!!!!!!!!!!!! SUZUKI EIGER !!!!!!!!!!!!!!! swampedeiger For Sale/Trade 1 01-30-2010 01:38 PM
