Clutching a 450 rhino - MudInMyBlood Forums
post #1 of 6 Old 05-31-2011, 08:12 PM Thread Starter
whoolieshop's Avatar
Have a buddy that has a 450 rhino that wants some more umph, I figure this being a CVT he could do some simple clutch work and pick up some bottom end. I also know he could get an aftermarket ignition and get rid of the rev limiter. Having a problem locating information on clutching the 450 everything on a rhino forum i googled was talking about swapping in rotax engines!
Anyway who should he look to for clutching? Papa slap? vforce john? airdam? someone else completely?
We're Just Like You.... Only Dirtier...
My Rides:
2005 Arctic Cat 650 H1 LE (Black)
2003 Honda Rancher ES (Rhino Linered Black)
1987 Yamaha Banshee
whoolieshop is offline
post #2 of 6 Old 06-06-2011, 04:58 PM
bamajeepjunkie's Avatar
I would get greaseless roller weights, maybe secondary spring, and shim or machine the primary (airdam, etc). utvinc.com is a good source.
TCM Bog Team Captain #42
Sponsored by: Mudtech inc., EKS brand , GearUpHelmets.com, and Mud-Throwers.com
MUD FLIES WHEN YOUR HAVING FUN
03 kodiak 450 modded, 01 big bear 400, 94 timber wolf 250, 97 Honda 300 4x4
bamajeepjunkie is offline
post #3 of 6 Old 06-06-2011, 06:09 PM
What Bama Said!
post #4 of 6 Old 06-06-2011, 06:57 PM
sloboy's Avatar
huntersworks does awesome clutch work for rhinos
13 900 Ranger,,just a lil lift!!!
08 Rincon, rolln on mayhems!
10 Rancher, its got a paddle!
sloboy is offline
post #5 of 6 Old 06-07-2011, 08:44 AM
Yeah hunterworks is good, but utvinc has more listed for the 450's. If he wants it to pull better 1-1.5mm shim, 12gram greaseless weights or 10 gram oem style and purple or gold epi secondary spring is the way to go IMO. Going greaseless helps by reducing rolling weight by being able to remove the grease cover and takes the hesitation out caused by the tackyness of the grease, the greaseless weights slide alot smoother.
post #6 of 6 Old 06-13-2011, 12:38 AM
primetime1267's Avatar
Good info guys, I have ben searching on this info as well. There are some many disputes on which shop has the best setup fro the Rhino 450, 660 & 700. I would like someone to use the exact same Rhino and do a COMPLETE test of each companies sheave/weights/springs and graph it out (MPH, 0-25ft, etc)..
So us readers can really see the actual differences between each shops tweaks to their kits. Ya know what I'm saying. I would gladly donate my ride for this purpose!
So if any of the BIG companies are reading this, send me one your kits for comparions(just for testing of course). And once all of the kits come in, I'll report the results.
2006 Sportsman 700 EFI---29.5 Outlaws s/s, gorilla axles, QSC clutch kit, 2" lift, snorkeled, Rad relocated
primetime1267 is offline
Clutching... Offroadin89 Kawasaki 61 05-04-2012 11:34 AM
27s to 28s Clutching? RWRIGHT Kawasaki 3 03-28-2011 07:19 PM
Clutching ?'s 08beast Kawasaki 22 10-29-2009 09:52 AM
clutching harmonsbrute Kawasaki 22 05-14-2009 08:55 PM
Clutching Help!!!!! bayou_boy_22 Kawasaki 17 04-29-2009 04:17 PM
