Looking for some general thoughts on 660's..... - Page 2 - MudInMyBlood Forums
post #16 of 19 Old 06-03-2011, 03:04 PM
bamajeepjunkie's Avatar
I like the greaseless rollers, I put a set in my kodiak. Who does the wet clutch delete for the grizz? I think you'll like it, as long as you keep in mind it's a single cyl.
TCM Bog Team Captain #42
Sponsored by: Mudtech inc., EKS brand , GearUpHelmets.com, and Mud-Throwers.com
MUD FLIES WHEN YOUR HAVING FUN
03 kodiak 450 modded, 01 big bear 400, 94 timber wolf 250, 97 Honda 300 4x4
bamajeepjunkie is offline
post #17 of 19 Old 06-03-2011, 03:12 PM Thread Starter
JPs300's Avatar
Airdam is working on it for the 660. He's got it done for the 700's; it's a complete kit, eliminates the wet clutch and swaps to a cvtech primary belt clutch to run a constant tension belt drive like a can-am. - If I end up with a 660 I'll be talking to him to see whats up with it. I'd pay and play genea pig to make it happen.
Single cylinders can get it done too. Anyone see the kitted 700 grizz that Flynt did? Almost 60hp @ the rear wheels, still pulling the wet clutch. - That's primed and ready to dink with a rotax's day.
https://www.facebook.com/in2deepmudders
'11 Max Limited -
JP's customs 4" lift, snorkels & rad relocate
30" Motoboss/MSA Pilots - 32's were fun, but not on the trails.....lol
'08 Teryx -
new build coming......
JPs300 is offline
post #18 of 19 Old 06-03-2011, 03:54 PM
Team BS
bump530's Avatar
JP...lafayette is about 2 hours from me...if he was closer, we could definitly go take a look
Team BS - Bayou Slingers
'94 Honda 300
29.5x10 Laws / Black 212's / FO-14 / Jetted / K&N / Clutch Kit / Snork'd / 424 / Lock'd / 54% GR / '88 Cam & CDI / Disk Brakes / 8000K HIDs / Start-in-Gear / Gorilla Axles
'05 Rhino 660 "Riverhino"
30" Zillas / 14" Black 212s / 3" Catvos / Stereo / Dipped Plastics / ViperMax 5000 / 8000K HIDs / 3" Snork / FO-4 / Jetted / 2m Shim / White Spring
bump530 is offline
post #19 of 19 Old 06-06-2011, 02:03 PM Thread Starter
JPs300's Avatar
He said he already has them available for the 660 as well. Requires the same custom shaft as the 700's, and same machine work to the side cover, just that they use different side covers.
...someone buy my honda......lol
'11 Max Limited -
'08 Teryx -
JPs300 is offline
thoughts on axles byrd Mud Pit 20 08-25-2010 01:20 AM
What's yalls thoughts? Brute650i Mud Pit 26 11-30-2009 11:09 PM
Brute says it's in 2wd, but it's in full time 4wd.. Thoughts? TEXAN AVIATOR Kawasaki 20 04-16-2009 08:00 AM
thoughts on bbk snorkel bruterider1080 Kawasaki 1 03-07-2009 07:14 PM
