Reverse light on not blinking - MudInMyBlood Forums
post #1 of 8 Old 10-27-2013, 02:06 PM Thread Starter
Wfolsom's Avatar
I have a 2002 prairie 650 and tge reverse light stays on
I started it up yesterday an tge reverse light came on an I backed it out of the garage to check it out more an also noticed the 4x4 wont work either so I shut it off an turn it back on an the lights off an 4x4 works an after 10 seconds tge light comes right back on I checked the two L shaped connectors behind the coolant bottle they make no difference plugged in or disconnected I also checked the battery connections checked the diode by the shifter an body know how to check the black square box (ecu maybe) not the CDI box
Can any body help me out here im lost
650 prairie, jet kit , 2" lift, 3 2" snorkels, dynatec cdi, 28" silverbacks
02 prairie 650
28' silverbacks
2" lift
3000lb winch
dynatec cdi
jetkit
foam uni filter
To be continuned ....
Wfolsom is offline
post #2 of 8 Old 10-28-2013, 12:36 PM Thread Starter
Wfolsom's Avatar
Anybody?
02 prairie 650
28' silverbacks
2" lift
3000lb winch
dynatec cdi
jetkit
foam uni filter
Wfolsom is offline
post #3 of 8 Old 10-28-2013, 07:39 PM Thread Starter
Wfolsom's Avatar
And today I mess with it some ab start an let it run for 20ins an it didnt come on .... go figure
02 prairie 650
28' silverbacks
2" lift
3000lb winch
dynatec cdi
jetkit
foam uni filter
Wfolsom is offline
post #4 of 8 Old 10-30-2013, 10:27 PM Thread Starter
Wfolsom's Avatar
Lil help here ?
02 prairie 650
28' silverbacks
2" lift
3000lb winch
dynatec cdi
jetkit
foam uni filter
Wfolsom is offline
post #5 of 8 Old 11-01-2013, 11:08 AM Thread Starter
Wfolsom's Avatar
171 views an nobody know how to test that ecu box ?
02 prairie 650
28' silverbacks
2" lift
3000lb winch
dynatec cdi
jetkit
foam uni filter
Wfolsom is offline
post #6 of 8 Old 11-01-2013, 01:01 PM
2010Bruterider's Avatar
Images: 29
Send a message via AIM to 2010Bruterider
Do you have a manual that shows the electrical circuits?
You said disconnecting the wire from the reverse sensor made no difference. That makes me think the reverse sensor is going bad. I don't know how the sensor works. But i imagine it's either normally open or normally closed to ground ( since there is only one wire on it). Try testing the sensor itself. It could be a wire that is skinned an intermittently touching the frame or something. I wouldn't assume it's the ecu till I tested the switch and the looked at the wiring harness good.
Sorry, but there are rarely any easy fixes to electrical gremlins.
2010 Brute 750. 29.5 OG s/w laws, VFJ stage 3, Kujo uppers, ASR lowers, rmax manual 4x4 (love it), full HMF exhaust w/snorkle, ODI Rogue grips, Viper 4500 winch, 55w HIDs, ASR tie rods, Gorilla axles, RDC 2" lift, MSD, MIMB 3" center snorkel and MIMB rad relocate.
2010Bruterider is offline
post #7 of 8 Old 11-01-2013, 05:16 PM
Onethej's Avatar
Well disconnecting the wire from sensor will cause the light to not come on at all under normal conditions. I would say the wire that connects to the sensor is grounding out somewhere. Remove plastic and start tracing it down. Prolly something pinching it against the frame causing it to ground out and turn light on.
2010 blue brute force
2" lift, Highlighter springs, 2" highlifter sig lift, 29.5 S/W outlaws, Dynatek fs,Full big gun Evo, Full 2" custom snorks, American star tie rods, Custom oil cooler, Digital temp guage, wild boar rad relocate, fundy high flow water pump, engine ice, 55w HIDs, pen lock,koplin backrest with cooler,4 speaker 800 watt Y-audio tube, Manual fan switch
4,000lbs viper winch with synthetic rope, Full aluminum products skid plates, Uni filter
Onethej is offline
post #8 of 8 Old 11-01-2013, 10:18 PM Thread Starter
Wfolsom's Avatar
Thank you for the info guys
Ill start the digging
02 prairie 650
28' silverbacks
2" lift
3000lb winch
dynatec cdi
jetkit
foam uni filter
Wfolsom is offline
FI light blinking Dflowers1990 Kawasaki 2 01-11-2013 08:39 AM
oil light blinking 650 brute ernieb62 Kawasaki 2 08-27-2011 07:58 PM
Reverse light on when in water?? gpinjason Kawasaki 6 08-08-2010 10:20 PM
reverse light crazy_maxx Kawasaki 5 03-29-2010 09:17 PM
Reverse Light??? TX4PLAY Kawasaki 3 08-12-2009 10:31 PM
