05 750 brute force no spark problem HELP!! - MudInMyBlood Forums
post #1 of 11 Old 07-23-2018, 07:25 PM Thread Starter
i have a 750 brute force thats having no spark problem on both cylinders just to start this out i bought it torn up the side case was open and the stator and flywheel was exposed to rain and had alittle rust on it so i cleaned everything back to pretty decent, i know the idiot that had it personally and know it had spark before i got it and replaced all the timing chains i made sure that the key way on the crank was good and put the flywheel back in place its spinning like it should, i have also checked voltage to the coils they both have 7 to 8 volts its had the buss connector fix on front and back already i have tried a different cdi box still nothing im stumped i build engines for a living but not small engines and this is killing me
prairie700rider is offline
post #2 of 11 Old 07-23-2018, 07:36 PM Thread Starter
just a quick up date the pulsor coil is showing 0.004 is that bad or good?
post #3 of 11 Old 07-24-2018, 12:50 PM
I think that's too low but take the manual and look it up. Oh..you don't have one? Here. Also, 7-8 volts on the coils is too low. Under 11 they won't charge. Should be the same as the battery-12.5-13.2. Pull the fuse box and pull all the connectors underneath.
Shared Files - Acrobat.com
post #4 of 11 Old 07-24-2018, 03:11 PM Thread Starter
i really appreciate the manual link ive looked almost every where with no luck for finding it im going out to work on it now i went by the stealership and got a keyway cause mine looked pretty sheared i should have changed it why i was in in there but im stupid and like to gamble but ill pull the connector and what look for bad connections or corrosion?
post #5 of 11 Old 07-24-2018, 03:12 PM Thread Starter
i really appreciate the manual! ill go out today and pull the connectors i need to look for corrosion or bad connection right?
post #6 of 11 Old 07-24-2018, 04:16 PM
That rotor's retainer must be torqued to what the book says....like 90ftlbs. Otherwise it will shear and if it breaks the crank-side keyway..like some have..it's a new crankshaft.
post #7 of 11 Old 07-24-2018, 04:23 PM Thread Starter
ive got everything together and right but no spark coils are showing 7.5 to 7.8 when starter is hit jumping around 5.0 its crazy could the pulsar coil be a problem?
post #8 of 11 Old 07-24-2018, 09:03 PM Thread Starter
so now im getting alittle spark but not constant i unplugged the cdi box and plug it back in and its now started sparking
post #9 of 11 Old 07-25-2018, 03:52 PM
Does that mean it's also running?
post #10 of 11 Old 07-25-2018, 06:53 PM Thread Starter
Not sure haven't tried it yet, but i am getting spark when i first hit the starter button. While it is turning over I no longer have a spark, but when i let off the starter button I get a spark. It is not constant, is it supposed to be constant?
post #11 of 11 Old 07-30-2018, 03:18 PM Thread Starter
so i pulled the cdi off cleaned the plugs cleaned the connectors on the fuse box added dielectric grease and it fired right up haha smokes alitte so i guess ill be doing a set of 840 rings and valve job here soon Thanks for the help!
Tags
05 brute force 750 , i need help!!! , kawie problems , no spark
'05 Brute Force 650 4x4 Running on one cylinder fortmyersjay2005 Kawasaki 3 01-18-2019 09:57 PM
2015 Brute Force 750 problems troubleshooting electrical!!! HELPP PLEASE BruteNasty15 Kawasaki 1 03-27-2017 05:30 PM
Brute force HMF problem Candy green Brute Kawasaki 1 05-10-2016 12:28 PM
Brute force clutch problem Bruterider84 Kawasaki 3 04-25-2016 07:02 AM
