2013 bforce 750i SE EPS - MudInMyBlood Forums
post #1 of 2 Old 12-26-2018, 05:51 PM Thread Starter
Bforce750i's Avatar
Hello, need help for problem im having,thinking it may be fuel filter or injectors from the posts that iv been reading, weird tho either way hope somone can help.
7200km 500hrs, 2013 , No major mods, plugs are good and clean , airbox clean, gas always clean going in.
The brute ran fine all day for a hour and then later on stopped for a few minutes to idle.
Started to go again and the bike would bog past 1/2 throttle, then get worse then get better and eventually was able to go 3/4 throttle no problem. Eventually could full throttle again without back fire.
It comes and goes somedays riding , please help anyway
Bb
Bforce750i is offline
post #2 of 2 Old 12-26-2018, 06:34 PM
Sounds like the vent check is stuck. Next time it happens loosen the gas cap. If it clears-up, replace it. If not, check fuel pressure and volume. Might have a bad pump or there may be water in the tank.
Tags
back fire , bog , brute , filter
2013 brute questions BruteNasty750 Kawasaki 3 05-15-2017 11:56 AM
2013 650 Brute Force SRA megabitez Tire/Rim 411 4 03-23-2017 01:56 PM
King Quad 750i Engine dies when turn in low speed Tasos Suzuki 1 02-06-2017 02:32 PM
2013 Brute 750 Front diff and steering question JS29 Kawasaki 8 06-21-2016 08:26 AM
2013 F150 Polaris425 For Sale/Trade 0 02-11-2016 10:06 AM
