2008 brute force sputters but if you flip kill switch off and on itís fine - MudInMyBlood Forums
post #1 of 8 Old 06-28-2019, 12:08 PM Thread Starter
I have a 2008 brute force 750i runs great for about a hour then starts to sputter and not wanting to take the throttle but I can flip the kill switch off and on and it’s runs great again for about 15 min. Does anybody know or have had this problem before
Deerhead334 is offline
post #2 of 8 Old 06-28-2019, 01:25 PM
Originally Posted by Deerhead334 View Post
I have a 2008 brute force 750i runs great for about a hour then starts to sputter and not wanting to take the throttle but I can flip the kill switch off and on and itís runs great again for about 15 min. Does anybody know or have had this problem before
I'm going to say either a charging issue making the coil voltage low or a grounding problem somewhere.
post #3 of 8 Old 06-28-2019, 04:01 PM Thread Starter
Alright thanks I’ll try that this afternoon and see at first it was sputter do to the fuel dock being stoped up but I went ahead and put a new fuel pump but then I noticed it was still sputtering a little so I put new spark plugs and 2 new coils and still has the same problem
post #4 of 8 Old 06-28-2019, 04:37 PM
Have you checked the injectors for operation? If anything got by the pump it will be in them.
post #5 of 8 Old 06-28-2019, 07:12 PM Thread Starter
I haven’t looked at the injectors yet but I wouldn’t see why they would act up and then be fine when I flip the kill switch
post #6 of 8 Old Today, 03:38 PM
How many times have you got it to run good again by flipping the kill switch off to on?
Moosiani is online now
post #7 of 8 Old Today, 03:43 PM
If it’s happened many times you need to look at it like this. Something is getting to hot and by switching it off and on your restring something. Do you know if your losing spark (weak spark) or fuel pressure ( lack of pressure. One simple cheap start would be switch the fuel pump relay with another relay and try it. I’d start there. Obviously this will be a process of elimination. I’ve seen relay flutter once hot. If it is your losing fuel pressure and volume. Also is the F1 illuminating when the problem occurs?
post #8 of 8 Old Today, 03:48 PM
I would also check all grounds to make they are tight and clean all relevant connectors. Doing this may not fix it but may prevent future issues. And it only costs some time.
