Research is starting on front lower A-arm and Rear knuckle bushings - Page 2 - MudInMyBlood Forums
post #16 of 21 Old 08-21-2012, 11:38 PM
HoNdAnAsTyRIDdEr09's Avatar
Need info will be replacing soon
2008 teryx murdered chopped cage,840 motor dual muzzys clutched m-12s 31s/w catvos 3in dynatek cdi/coils vfj stage 3 custom audio top wit 8-8in fosgates 4-6.5 fosgates 4000watts 3in intake snorkle
05 brute "desert gold" ,back up bike on 14in nukes an 28 in zillas it's got the works
HoNdAnAsTyRIDdEr09 is offline
post #17 of 21 Old 08-23-2012, 05:12 PM Thread Starter
Brute650i's Avatar
both designs have had to short of a life span. We are going to have to do some more tinkering with the design. We have a design that will work 100% but it will be around $250 a set (Both sides uppers and lowers) which is a pretty high price to me I would like it to be around $175-185
2011 Polaris Ranger XP800
2005 Ford Crew Cab F-250
Need Eagle Eye HID's, KUJO A-arm Bushings, MSA Rims, EFX tires, Highlifter Products, ITP Rims, OEM Parts contact me @ [email protected] or B&Cracing-Home
MIMB Members Map
Brute650i is offline
post #18 of 21 Old 09-25-2012, 08:33 PM
huntertibbs's Avatar
I'm interested in both when everything gets worked
Sent from my C771 using Tapatalk 2
huntertibbs is offline
post #19 of 21 Old 11-04-2014, 03:19 AM
fiarmin67's Avatar
I see it has been a while since this thread has been resurrected. My Brute took a tumble off of the trailer this week and once i get my insurance check (best $12 a month i have ever spent) i want to rebuild all 4 corners uppers and lowers. Has there been anything for rears and front lowers?
Brute Fore 650i on 28" 589
Fan Switch Mod and TTO Temp Gauge
MIMB Snorkel and Split Audio Tube
EPI Maroon Pri and Almond Sec
Future:
Gorilla 3000XT Winch
HMF Swamp with Snork
fiarmin67 is offline
post #20 of 21 Old 11-04-2014, 07:35 AM
Coolwizard's Avatar
You can get front upper and lower a-arm bushings from ASR
2017 Polaris Ranger XP 1000 North Star HVAC edition/3"SATV lift/28"STI Chicanes on MSA Beadlocks/5000lb Viper Max/ SATV rear Roll Bar/SATV rear Bumper/
13.25" LED front light bar/4" LED light cubes/In-dash garage opener/horn
2010 750 Brute (CAMO) 26"Big Horns on ITP 312's, Viper Max 4000lb winch, Kawi rack extentions.
Coolwizard is offline
post #21 of 21 Old 11-04-2014, 07:50 AM
Right and the ASR front lowers do fit the rear lowers as well (I'm told). The rear uppers are rubber. The knuckle bushings...well its best to replace them with stock bushings, sleeves and seals and make them greasable.
rear knuckle problem KEVIN24 Kawasaki 5 02-23-2011 12:44 AM
Dynojet Procedure 2006 BF750 & Lower Front A-Arm nathangunn28 Kawasaki 1 07-27-2010 06:46 PM
front right lower a arm CreepinDEEP Want to Buy 0 04-07-2010 01:27 PM
Rear Knuckle Greg G Kawasaki 2 03-18-2010 10:49 AM
Brute force 750 rear knuckle rt/side BIG EASY Want to Buy 0 02-03-2010 05:55 PM
