Bottom end rebuild kits $755 shipped - MudInMyBlood Forums
post #1 of 31 Old 06-04-2011, 08:14 AM Thread Starter
Brute650i's Avatar
Brute force rebuild kits come with new crank, both rods, base gasket, head gaskets, timing chains,front and rear seals, and all 3 sets of rod bearings to get clearances in check to ensure a long lasting build.
When I get back to the office I will post a list of part numbers and retail prices.
2011 Polaris Ranger XP800
2005 Ford Crew Cab F-250
Need Eagle Eye HID's, KUJO A-arm Bushings, MSA Rims, EFX tires, Highlifter Products, ITP Rims, OEM Parts contact me @ [email protected] or B&Cracing-Home
MIMB Members Map
Brute650i is offline
post #2 of 31 Old 09-05-2012, 11:55 PM
chevzr2's Avatar
do you still do these kits at 700?
HIS
'12 BRUTE 750, 2 INCH RDC LIFT, MUZZY SUPER PRO DUALS, MUZZY DIGI TUNE, VFJ CLUTCHING, 28'' OUTLAW 2'S, 28'' MSA ELIXERS BLACK, TEMP GAUGE, OIL COOLER, UNI, SNORKELED
HERS
'09 DSC 801 BBK, (840 ON 650 BOTTOM END) MSD, MUZZY SUPER PRO DUALS, UNI, 2 INCH RDC LIFT, 28" MEGA MAYHAM'S ON BLACK MSA CRUSHERS, VFC CLUTCHING, SNORKELED, OIL COOLER, TEMP GAUGE, AFR GAUGE.
chevzr2 is offline
post #3 of 31 Old 09-06-2012, 08:07 PM Thread Starter
Brute650i's Avatar
I will have to check and make sure that prices have not changed but should be same price. The cranks were on backorder even straight from kawi last time I checked so I'm not sure if that has changed.I will post back when I check prices.
MIMB Members Map
post #4 of 31 Old 09-07-2012, 07:10 AM
in need of a kit ,more imfo please
post #5 of 31 Old 09-07-2012, 07:32 AM
chevzr2's Avatar
hope its all good, i need one.
HIS
HERS
chevzr2 is offline
post #6 of 31 Old 09-08-2012, 11:48 AM Thread Starter
Brute650i's Avatar
just checked prices anf both cranks and rods have went up. New price is $755 shipped. New crank, rods, bearings, front and rear seals, head and base gaskets, and all 4 chains.
I still need to check if cranks are available so let me know if your interested still
MIMB Members Map
post #7 of 31 Old 09-08-2012, 08:20 PM
chevzr2's Avatar
still interested for sure, let me know, thanks
HIS
HERS
chevzr2 is offline
post #8 of 31 Old 09-08-2012, 08:54 PM Thread Starter
Brute650i's Avatar
Monday morning ill call and check with them and let you know.
MIMB Members Map
post #9 of 31 Old 09-09-2012, 03:00 AM
chevzr2's Avatar
sounds good, i need the kit, doing a project on a 09 750, std bore kit going in.
HIS
HERS
chevzr2 is offline
post #10 of 31 Old 03-20-2013, 06:47 PM
Did I just miss it or ? Where can a rebuild kit be purchased? Company name and info? Thanks
ffmedic6320 is offline
post #11 of 31 Old 03-29-2013, 09:24 AM
mikenick937's Avatar
Original post was from 2011.. lol
mikenick937 is offline
post #12 of 31 Old 03-29-2013, 03:16 PM Thread Starter
Brute650i's Avatar
I can still get them but with increases in parts cost the price will not be the same. Also last I checked there was a national backorder of cranks which should be hone by now but I haven't checked. Pm me for prices and to discuss details
MIMB Members Map
post #13 of 31 Old 01-05-2014, 11:27 AM
I'm reviving this thread from the past, do you still offer this kit?
If so, does it include the main crank bearing and could it be supplied, installed in the crank?
sed8ed is offline
post #14 of 31 Old 01-05-2014, 07:07 PM Thread Starter
Brute650i's Avatar
Still can do the kits but pricing may have changed. I would have to check. I would have to check and make sure that bearing is able to be bought separately and if so can be supplied. I can check on all of it tmrw if you would like and get make to you.
Thanks Brent
MIMB Members Map
post #15 of 31 Old 01-07-2014, 11:34 AM Thread Starter
Brute650i's Avatar
Is ut left or right side bearing you are talking about? If you could send part number that would be good but if not i should be able to find it. One side can't be bought oem
MIMB Members Map
Bottom end rebuild bruteforce3 Kawasaki 15 02-15-2014 05:24 PM
TRX 300 all balls rear diff rebuild kits Nate_1503 For Sale/Trade 7 08-30-2012 07:05 AM
Stock CDI - $45 shipped No Plugs For Sale/Trade 3 11-22-2011 07:10 AM
Best Place To Buy Engine Rebuild Kits for Brutes? muddmonkey Kawasaki 12 02-27-2011 08:57 AM
Lift kits and Long travel kits C_Holland General Tech. & Audio Info. 18 04-16-2010 03:06 PM
