650/920 brute crank setting? - MudInMyBlood Forums
post #1 of 11 Old 02-28-2013, 07:34 PM Thread Starter
DSmith's Avatar
My cousin gave me a 04 brute 650 with 31" laws a couple years ago, with a wore out crank. I'm just now gettin around to building it. Since I was gonna have to buy a crank I went ahead and got the 920 big bore kit. My question is at what position to timing should this v twin be set? Single cylinder and v8's I know but I just wanna make sure I put this high dollar kit together right before I bust it off. Thank you to anyone willing to share knowledge with me in this matter.
DSmith is offline
post #2 of 11 Old 02-28-2013, 07:45 PM
02KODIAK400's Avatar
04 brute?
02KODIAK400 is offline
post #3 of 11 Old 02-28-2013, 08:59 PM
Brute650i's Avatar
920?
---------- Post added at 09:59 PM ---------- Previous post was at 09:57 PM ----------
I should say 920 on prairie 650 heads could be a pita to get it to hold a head gasket if it ever does. Hope it has brute 750 cylinders but that Requires the case to be bored
2011 Polaris Ranger XP800
2005 Ford Crew Cab F-250
Need Eagle Eye HID's, KUJO A-arm Bushings, MSA Rims, EFX tires, Highlifter Products, ITP Rims, OEM Parts contact me @ [email protected] or B&Cracing-Home
MIMB Members Map
Brute650i is offline
post #4 of 11 Old 02-28-2013, 10:31 PM Thread Starter
DSmith's Avatar
04 brute, 700 cylinders with 89 sleeves/pistons, 750 crank, close but claims to work. we'll see at mud nats! but I still need the timing specs. aint havin much luck on downloading it anywhere.
---------- Post added at 11:31 PM ---------- Previous post was at 11:08 PM ----------
Originally Posted by 02KODIAK400 View Post
04 brute?
sorry its a 05, thinkin bout one bike typing about another
DSmith is offline
post #5 of 11 Old 02-28-2013, 10:55 PM
brutemike's Avatar
Shoot down south customs DSC on here a pm or maybe just call him i hear he will answer all ? if he can.
2011 750 brute
custom racked rad
3" mimb center snorkels
maroon primary & red secondary
2" RDC lift, oil cooler
29.5" outlaw2's on ss212's
1.5 wheel spacers back only
split audio tubes
penloc,grease zerks
viper max 4500
brutemike is offline
post #6 of 11 Old 02-28-2013, 10:58 PM
bigblackbrute's Avatar
you are talking about cam timing correct?
09 BRUTE 750
FUNDY PERFORMANCE MOTOR & VFJ STG 3 CLUTCH
31S AND 2IN LIFT
ASX TIE RODS
FULL BIG GUN & MAPPED MSD
BACKREST & AMMO CANS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
CUSTOM RAD MOUNT AND BIG FAN
BUILT BY FATBOYZ CUSTOMZ
bigblackbrute is offline
post #7 of 11 Old 03-03-2013, 07:11 PM Thread Starter
DSmith's Avatar
yes the entire timing, have markings on everything but crank
DSmith is offline
post #8 of 11 Old 03-03-2013, 08:58 PM
The markings are on the flywheel. Install flywheel and startor cover take big plug out the top of stator cover it takes a big flat head screw driver. U will be able to see timing marks through that hole. Start with back cylinder.
fatboyz customz
09 BRUTE 750
31S AND 2IN LIFT
ASX TIE RODS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
post #9 of 11 Old 03-04-2013, 05:32 PM Thread Starter
DSmith's Avatar
alright thanks
DSmith is offline
post #10 of 11 Old 03-04-2013, 07:02 PM
No problem man. There is a way to time it without the flywheel but its kinda hard to explain. Using the flywheel is real simple
fatboyz customz
09 BRUTE 750
31S AND 2IN LIFT
ASX TIE RODS
CUSTOM ODI GRIPS
VIPER 3000 ELITE
post #11 of 11 Old 03-05-2013, 12:33 PM
the fly wheel key way groove on the crank is what I use,there are lines on the inside of the case the groove on the crank for the key way has to line up with the rear line to instal rear cam and front line to do the front cam,you need to get you a manual it makes this alot easier,I can do it with my eyes closed but explaning is harder
2005 Brute Force 650
SRA Drag Bike Kawie Green
Stretched & Slammed
FST 840!!!!
2012 Kawie Green
Teryx Sport 750!!!!
Brute 840 is offline
WANTED, BRUTE 750 CRANK/RODS. or just crank chevzr2 Want to Buy 6 07-14-2012 08:06 AM
what jet setting? Saintsation Kawasaki 1 03-11-2012 05:28 PM
setting the timing countryboy61283 Kawasaki 8 11-09-2011 07:07 AM
Suspension setting on BF 750 beach83 Kawasaki 7 11-15-2010 08:17 AM
setting floats browland Kawasaki 4 11-16-2009 06:45 AM
