Instructions for MudInMyBlood Center Snorkels: http://www.mudinmyblood.net/forum/view.php?pg=brutesnorkel
*Note: These are for 650i/750i 650SRA will have to make modifications for it to work.
Vent list From gpinjason:
1. Gas tank vent need to remove from frame, and add hose to the pod.
2. Coolant overflow bottle vent line needs to be re-routed and extended to the pod.
3. on Carbed models (05-07 750, 06-present 650i) remove white canister from vents, replace it with a "T" connector, and run vent to pod. EFI bikes don't have any vents here.
4. Seal "duckbill" drain on Airbox. I pulled it off, filled it up with silicone, and stuck it back on and let it dry.
5. Diff vents should already be ran to the pod, but if it's an older bike, it's good to inspect them, and make sure they are good. The rubber tubing is cheap, if you have any doubts, replace them...
6. Make sure the little vent tube from the radiator fan motor is ran to the pod.
7. OPTIONAL: remove the crankcase vent from the airbox, and extend it to the POD, and put a small filter on the end to keep dust out. Another option for this would be to do a catch can mod, if you do lots of wheelies, water wheelies, or WOT runs...
Some of these may already be relocated from the factory, but it never hurts to check. Also, if you plan to ever go deeper than the handlebar POD, it's a good idea to re-route them to the same height as your snorkels.
