1 - 11 of 11 Posts
i have a 750 brute force thats having no spark problem on both cylinders just to start this out i bought it torn up the side case was open and the stator and flywheel was exposed to rain and had alittle rust on it so i cleaned everything back to pretty decent, i know the idiot that had it personally and know it had spark before i got it and replaced all the timing chains i made sure that the key way on the crank was good and put the flywheel back in place its spinning like it should, i have also checked voltage to the coils they both have 7 to 8 volts its had the buss connector fix on front and back already i have tried a different cdi box still nothing im stumped i build engines for a living but not small engines and this is killing me
just a quick up date the pulsor coil is showing 0.004 is that bad or good?
I think that's too low but take the manual and look it up. Oh..you don't have one? Here. Also, 7-8 volts on the coils is too low. Under 11 they won't charge. Should be the same as the battery-12.5-13.2. Pull the fuse box and pull all the connectors underneath.
Shared Files - Acrobat.com
i really appreciate the manual link ive looked almost every where with no luck for finding it im going out to work on it now i went by the stealership and got a keyway cause mine looked pretty sheared i should have changed it why i was in in there but im stupid and like to gamble but ill pull the connector and what look for bad connections or corrosion?
That rotor's retainer must be torqued to what the book says....like 90ftlbs. Otherwise it will shear and if it breaks the crank-side keyway..like some have..it's a new crankshaft.
ive got everything together and right but no spark coils are showing 7.5 to 7.8 when starter is hit jumping around 5.0 its crazy could the pulsar coil be a problem?
Not sure haven't tried it yet, but i am getting spark when i first hit the starter button. While it is turning over I no longer have a spark, but when i let off the starter button I get a spark. It is not constant, is it supposed to be constant?
Discussion Starter #11
so i pulled the cdi off cleaned the plugs cleaned the connectors on the fuse box added dielectric grease and it fired right up haha smokes alitte so i guess ill be doing a set of 840 rings and valve job here soon Thanks for the help!
1 - 11 of 11 Posts
