1 - 3 of 3 Posts
Hey guys i bought a blown 07 brute force 750 and have found a built 06 engine that i could buy, im almost positive that they will swap over no problem but i'm not entirely sure if there would be any problems with it. also if there aren't any problems with a 06 swap what other years of 750 motors will work with it? Any help is greatly appreciated thanks in advance.
05-07 were all the same engine for the 750. The 08-11s will also work except you will have to change the stators and pulse coils and if you want the pull start, you will have to get those parts. Also the vacuum port for the pulse fuel pump was just capped on the 08s and 09s but was deleted later all together.
1 - 3 of 3 Posts
