1 - 3 of 3 Posts
I am working on an 08 brute force 650. I have no spark on either cylinder. Using the factory service manual I have found a couple of things:
Primary coil windings read .4 instead of .09-.13 and secondary is 10k instead of 3.8-5.8k
Crankshaft sensor reads 113 instead of 423-517
I find it hard to believe that all three of these went bad at the same time and am leaning towards the sensor. The rollover sensor is good (.74)
I do not have the tester to do the peak coil voltage test as described in the manual
What are your thoughts?
I had a similar issue once before and it was my CDI box had went bad.
1 - 3 of 3 Posts
