Hey guys (and gals), first post after a lot of reading around. As the title says I have an 08 Brute 750 that seems to be running rich (black smoke - and the fuel smell you would associate) It also will stall if no throttle is given. I just completed a valve adjustment which took my about six tries to get rid of my ticking. While I was at it I threw on a full "Big Gun" exhaust, I also replaced the plugs PRIOR to adjustments, when things seemed to be working well.
While in the mist of adjusting the valves it would run fine (minus the clack), mind you I had already swapped the plugs -no exhaust yet. I followed the infamous youtube video for adjusting my valves after having no luck using the shop manual method (TF - too frustrated? TR - too retarded?). I went .005 on the intake and .007 on the exhaust. My best guess is things are too tight, however I never had a "rich" issue before I adjusted my valves and they should be at least looser than before???
I'm just looking for a few opinions. Thanks in advance!
PS the gun sounds nice! Need some bite to go with the bark now!
