1 - 10 of 10 Posts
I am building a King Quad for a buddy of mine ( the bike I was on when I got HIT ) and wanted to know if there are any tips and tricks you can do to the bike to make it better??
haha... I need something a little lighter for the dudes pockets but I do have one...
Oh yeah, how deep is his pocket? LOL! For a really Great combo
1= VDI & M109R injector
2= EPI yellow spring & 18 gram weights/green spring & 16 gram weights
3= Coop45 (shim mod) really cheap & easy to do
4= Twin Air filter with cage(easy to seal up water tight):bigok:
5= Yoshi(my choice)/Pro Circuit/HMF exhaust the PC & HMF are gonna be Loud!!
This will make for a Very Impressive package & each item only complements the others!!!! :rockn: Holla Back if you need Nemore info on these mods! L8r Brandon
Coop45 Shim mod??? Please do tell more...
The full shim thickness is 2mm though some folks can't get the full 2mm they usually go with 1-1.5mm.. It's a Yamaha part from a snowmobile & it's used to shim out the Primary in order to get a lower gear ratio(approximately 11%)lower :rockn:!!!! It makes the Kings come alive!! Hope this helps & L8r
Tell shim to go to the local Yamaha shop. Tell'em sookie sent ya'.
They'll have you smokin' tires in no time!!!!!!!!!!!!!
:rockn::rockn::rockn::rockn:
Just sayin'
Hay coop45 you just did my buddy's clutch he likes it so far. It has allot more low end now he said. We will give it a good test on the 28th. (the grizz in MN you did last week)
Whats up Coop? Glad to see you on here. Come back more!!
I have all his mods....1,2 & 3. It's helped my bike a LOT!!! I have a ton more low end. I can't explain how much better it is off the low end. Mod #3 is the bomb.
1 - 10 of 10 Posts
