1 - 5 of 5 Posts
What is the best aftermarket ecu for a 09 brute force 750. I believe mine is bad cause my fuel pump kicks on for a second and won’t kick back on also I’m getting low voltage to my injectors. And I don’t want to buy a new one cause it’s $630
Super Moderator
I think you should check or test the vehicle-down sensor as both power supplies are routed through it first. It may even be in upside down...it's happened. The connector may also be corroded.
1 - 5 of 5 Posts
