First thing to check is your fuses, then is there power at the breaker. Make sure you have a good ground to the fan. Did you jump power to the fan to determine it was ok? Check the connector to the fan and make sure its not filled with sludge or corrosion.
you said your getting power to it, are you getting power out of it, they will corrode and loose connection
The breaker is like $2.50 at the dealer or just put a fuse in it
