1 - 10 of 10 Posts
i snorkled my brute...run good too start with then started busting out and popping when going between 0 too bout 25 then smooths on out...ne ideas what i didnt do or need too do?used the mimbs snorklin
What model is your Brute 650 SRA, 650i or 750i?
^ and do you have stock or aftermarket exhaust?
750 i,,,,stock exaust,,,will post rest of profile later when i can get pics uploaded and a little more time
did you use the 3" rubber elbow for the airbox? Or did you use the 2"?
Also, you may try removing the screen under the air filter to regain a bit of airflow
used 3 inch and cut like directions said...will remove screen,,,also gonna takes sides off too make sure something didnt come loose from all the work round the wires
big p i used 2" and didnt remove screen on my 08 and have no problem just lucky???
I have an '08 Fuel Injected 750i and I used a 2" rubber 90 and 2" piping on the Air Box...Didn't remove the screen or anything and I have not had any problems...Just figured I would throw that out there...
1 - 10 of 10 Posts
