1 - 7 of 7 Posts
I have a 1996 Polaris 350L trailboss. I bought recently as my first utility quad and it ran decent and I could ride it the first 2 days. Well I let my brother ride it and it broke down and wouldn’t start. I pulled the plug it has spark (blue) and compression from what I could feel. I took apart carbs cleaned them and it still won’t start. I held my hand over the carb (where air box connects) and it didn’t even try to suck my hand in. When I spray gas inside carb it will start and just rev and die. Not sure what it is please help!
sounds like it's not getting fuel to the carb.
Discussion Starter · #4 ·
How would I go about fixing that? There fuel in the carb bowl?? But it’s damn near dry in the upper part.
Look at the case seam bellow the carb. They were notorious for cracking the piston skirt and a piece wedging under the crank and cracking the case under the carb. Worst were the pistons with 2 slots on the intake skirt.
^ What he said... plus checking the diaphragm (they get crusty) and your jets could also be clogged up.
Just realized the last year for the 350 was 93. After that it was a 400. Same issue but not as common on the 400. Polaris used round slide Mikuni VM carbs on all the 2 strokes. First with the diaphragm carb was the 425 4 stroke .
1 - 7 of 7 Posts
