Highlifter states that with the 2 inch lift you need 1" wheel spacers in the rear, I have read this is because the upper control arm will rub the wheel. So my question is can you run a 5x2 offset wheel and get the clearance because people say stock is more like 5.5 x 1.5. Is my only option a 4x3 or has anyone gotten away with a 5x2 and if so with how much space to spare?!?!? I have a 2017 brute force 750 eps Thank you!!
Yes a wider offset wheel will solve the problem, with no need for spacers.
Depends on the tire you're running... if they have a large side lug, then a wider offset. If they don't then you won't need much offset at all. I believe when I had a HL 2" lift and 29.5 OG Outlaws I ran 5+2 and had plenty of clearance.
