1 - 2 of 2 Posts
My wife owns a Honda fourtrax 350. Last fall the brakes went in her quad. Brake Pads are fine, I have replaced the spring and made sure their are no leaks. Her brakes still have a lot of play and are not braking at all. It won't hold brake fluid, but I am looking for leaks.
Any ideas?
I'm assuming you are refering to the shoes?
You probably have them adjusted improperly/too loose. Try moving the star adjuster the other way. I've seen it way too many times now.
And BTW, if you are losing fluid, your leaking.
1 - 2 of 2 Posts
