I have a 2002 honda foreman rucibcon trx500fa. When i put it into drive it and give press the throttle it feels like it wants to move but doesnt. I retrieved the code and it was 6 blinks stating the angle sensor or ecm. i do not have a spare ecm to use as a tester to verify if the ecm is bad. I tested the angle sensor and verified it was good. The bike does the same in reverse. When i start it up esp d1 d2 and gear position just flash.
i was told by the previous owner he replaced the brains behind the light on the steering column. and also that when he previously had the problem he messed with the gear linkage to rectify it but hes not sure what he did.
