Top ends are usually a piston, rings, probably boring or a new cylinder, a valve job which means re-grind or new valves, seats recut,seals cam chain and sprocket, tensioner bar, gasket set. In all usually under 800 for a little single like that. Sense you are asking I assume this isn't something you are equiped for so there will also be labor costs as well.
