1 - 7 of 7 Posts
Morning I have gone through all the sticky posts and have checked and double checked connectors and actuators and still no solution.
Everything was working fine when I took everything apart to change my damaged stock primary out with a cvtech primary clutch. The lights started flashing when I started the quad up with no primary or secondary clutch installed on the bike was not flashing when I started it up with the clutches in place and cover removed.
Put it all back together and still flashing.
Any suggestions on what I could have caused by firing it up with no clutches in place and how to reset ?
Thanks
Clearly the actuator and belt switch are unplugged in the pic so starting it like that would have send an error code. That will have to be re-set. Follow the procedure to reset the belt error code. Next time if you are going to even turn the key on with the cover off, set it on the seat with everything still plugged in. The harness is long enough.
NMKawirider
Thank you for the reply i did the belt reset procedure with the grey and black under the seat and i even went back after your post and tripped the switch to make the belt light flash and then did the procedure and reset the light fine but it still is flashing 2x4 / 4x4 and i went a bit further and pulled the 4x4 actuator from the front diff and plugged it in to the kebc actuator and it tested fine and the kebc actuator is cycling fine so both actuators are working.
It started flashing when i started it without the cover off and disconnected and both primary and secondary removed from the clutch assembly.
At a loss what to check next if you have any more ideas would be glad to give them a go.
thanks again
NMKawirider
thanks again
With the 2/4wd light flashing one of the actuators has a problem or the system had a problem..ie a bad connection or the speed sensor has a problem.
KEBC actuator bypass? Sorry on my phone so unable to search but have figured out the actuator somehow kicked the bucket and causing the flashing 2wd/4wd so with no need for the engine break now is there a way to bypass it but the bike thinks it's still there not causing the flashing lights?
The quad is in 4x4 mode and wont change into 2wd no matter what I have tried so just gonna try to bypass the brake actuator and then drive in 4x4 till it dies lol.
My switch went bad and caused a similar issue
Switching to the CV tech? How do you like it?
I have been looking into this clutch on the BF as well. there is a guy on youtube www.youtube.com/watch?v=7h1z05kk7_w
that has done it and the Actuator Lever Assembly with the fork had to be removed leaving the actuator in to fool the controller.
1 - 7 of 7 Posts
