1 - 2 of 2 Posts
I have a 2006 brute force. It has a fresh top end but the piston is hitting one of the spark plugs causing it not to turn over. Take it out and obviously it turns over. It was running great and all of a sudden it just stopped. Any ideas of what caused it?
Someone put the wrong plgs in it? Or did the fire rings get left off? I wouldn't think a timing issue cause the plug is static and the piston only goes up so high..unless she spun a bearing or broke a piston. Someone didn't shave the head or deck the cylinder too much? Only guessing..you will have to do some measuring.
1 - 2 of 2 Posts
