1 - 1 of 1 Posts
Good day all, trying to diagnose my 2008 brute force 750i that has a FI light that flashes 6 long and 1 short. I'm guessing it is 5 long and 2 short (since there is no code 61) indicating a ignition coil malfunction. I have replaced both coils with no success. Is there a specific way to reset the FI light?(I removed the positive terminal rom the battery for a minute and disconnected the cpu) also I did have a copperhead vdi installed before but it shorted out on me (the metal shell of the copperhead grounded out and melted its guts) so I'm back to the original ECU which worked fine before. The bike idles fine just has a big hesitation when hitting the throttle. Tried to add a video of the code but it was to big. I have removed the fuel pump, replaced filter, drilled out screen and cleaned the tank. Noticed my battery has a low charge when not running, would this cause the ECU not to reset the fi light and stay in limp mode?
Thanks for your time !
1 - 1 of 1 Posts
