1 - 3 of 3 Posts
Is there an option for a fuel pump relay replacement that's not a Kawi Part number? #27002-1062
$30+ seems a bit much for a replacement factory relay....
There's usually people parting out brutes in the "for sale" sections.
FIXED MINE! Tested all the wiring. Tested the ECU(serveral times) ground, positive, wiring going to fuel pump relay. Finally determined what I did not want to hear. BR/Y pin 30 from ECU to relay was not sending signal. Bad ECU. Found a used one for $300, as opposed to $630 for new. 5 minute install, all good. All started at fuel pump filter. Completely clogged. It would freeze the pump motor.Popped the tank with a rubber mallet. It would work for a bit, finally quit. Replaced the pump but no juice. I assume the old frozen one caused the ECU to stop throwing the signal. New/used ECU fixed the pump signal. Hope this helps someone else. The pump filter is very fine screen and small. Every one should change it once a year at least. Not that hard, just time consuming. Enjoy the ride!
1 - 3 of 3 Posts
