1 - 8 of 8 Posts
So my brute seemed as if it was running on one cyl so I was messing with the connectors to the ignition box and when I touched the right one it would run on both, I pulled the pin on the connector and it was broken I need some help finding the right pin part number I’ve see some similar but not exactly the same any help would be great thanks!!!
Thanks guys, I don’t see the p/n there I’m still searching I’ll add them to the list if I find them
If you will tell me what color the wire is I’ll cut it out for you and send it free of charge. Just have to solder it in then.
Dude that would be awesome, it’s the black and yellow and the blue and white wire in the 4 connector to the ignition box
Ok I’ll get out this evening when it cools off and get them for you
1 - 8 of 8 Posts
