1 - 3 of 3 Posts
As the title says I blew my main fuse and lost all power to the dash and the bike shutdown. Put a new fuse in and now I can't seem to get spark. I just installed a new stator and crankshaft position sensor last week. Could the CPS be bad already?
Once you replaced the fuse, do the dash lights work now? did you make sure the fuse you put in was good? do you know what caused the fuse to blow? I would think if it was a stator issue it would blow the new fuse.
Blowing the main 30 amp fuse is a major event. Dead short somewhere...and those don't come without secondary casualties. I'll bet what ever did it also took out your ECM so get the manual and start testing. And by all means find the cause of that short first.
1 - 3 of 3 Posts
