1 - 20 of 183 Posts
This is not intended to be a "how to"...rather an UPDATE to the MIMB snorkels.
This is the way I did it...I'm sure there will be other ways...better ways ;)
Here the bike is naked to get a good idea of what you are/will be working with
First step is to remove all the stock snorkels/guards/plastic. You remove EVERYTHING under the front fenders, there is the airbox snorkel, splash guard, and plastic insert for the electronics (SAVE THIS PIECE) we are going to cut up later
Then you can plumb up your CVT Exhaust first...
Just like 08+ brutes, 90* street to 22.5 to 45/90/90 then riser
Next we are going to work on the CVT INTAKE
Take the stock piece off...
Cut it at about 7" from the bend that comes up(just below the tab that holds the wiring) (you will see what I'm talking about when you do it)
Put a 2" rubber 90* coupler on it (2" works...you just have to stretch it), you are going to face this towards the left side of the bike!
Now build your riser...
Mine is a little piece of PVC, then a street 90*, then about 3-4" of pvc to a 45* to another 45*
What you are essentially doing here is clearing the handlebars and getting the snorkel to sit straight up. This took a lot of time for me to figure out! But it works!
Now you can do your airbox...
3" rubber 90* cut off the ends, you have to remove the computer module from the frame to get in there...it's extremly tight. Something is different with the steering obviously, but it almost does not fit the 3" 90*
I then used a 45* to a 90* and it fits perfect! Just put a little piece of rubber between the bushing and the 3" 90* so it doesn't rub through.
I did not use a single zip tie on the snorkels! They fit perfect!
Before you pt the plastics back on, di electric grease all the connectors and ALSO zip tie them out of the way. It is extremely tight under the fenders and dont' let anything bounce around!
I cut the front piece with the rollover sensor so that it just has the front little portion (you will see what I'm talking about) that is all that fit. I wanted the rollover sensor mounted correctly and also the ecu to have a mounting point. They do not fit in the stock location but I zip tied them down!
Then you are going to cut the lip off the front fenders around where the snorkels go, PLUS about 1/4-1/2" for the curve of the snorkels.
Then take your shroud and cut the shiney part out 1/2" above the bolt hole all the way to the top. Also going to need to trim and round out for the 2" rubber couplers!
I make the rubber couplers sit on top of the plastics, holds them good and a good reference point so they are all even.
A work in progress
This isn't mine! It's a friends I am doing up for him...but doing this is making me want a 12!
A little off subject but i like that color lol. Almost matches my truck
P, could you swap this to my thread from the Kawi section? Or I can just edit it
Should be wrenching instead of using TapaTalk
Should be able to edit.
Try Tapatalk!!
Thanks P!
How did you cut the plastic piece where the pipes come up at the handle bars? Im trying learn as much as I can before I attempt to snorkel my 12
There is a template on this site you can print off to put on the plastic shroud to cut the holes needed for the snorkels to come threw , or just cut the entire middle piece out of where they will come threw and zip tie them all together to help hold them together if needed
Do you think a 3" center intake snorkel would fit like the 08-11's? I was also wondering if any part of your handlebars hit the snorkel tubes at full lock?
I never got into the 3" snorkel craze. Never saw a need for it as 2" does really just fine!
As for cutting the shroud I just do a square cut just pretty much the entire smooth part. Then a little more on the edges. Mine never move. No zip ties here... Just as the tips of the snorkels to hold them tight and even
Discussion Starter #12
I don't think that it will fit. It's extremely tight just doig 2". And the center snorkel hits where the ecu sits. You may be able to do it with extreme modding
Discussion Starter #14
I don't want to discourage you...it may fit but I do not think there is enough room. It was a pain to get them all to fit right...
Discussion Starter #15
Also wanted to ask what mods you have that require 3" snorkel? 840?
this is completely off of the subject but does he have spacers or a lift if so what kind?
Discussion Starter #17
2" RDC lift, 1.5" WHEEL spacers, no spring spacer or anything like that.
getting ready to do mine. i have the exact same bike.
i was just curious on air/fuel ratios being affected at all. or does the EFI map itself out to adjust? any additional mods one is going to have to consider when doing the MIMB snorkel kit on the EFI 2012 EPS 750?
thanks
Discussion Starter #19
I just raised the vent lines. Front diff, rear diff, gas tank vent, and crankcase breather I put under handlebars.
The efi doesn't "adjust" at all so I've read. But it does just fine with snorkels. I even checked the plugs and they were fine!
Its a tight fit with the two inch I helped a buddy do his. You might be able to with flex hose but not too sure on that.As for the three inch ive had it on my 2011 from the sixty mile mark and now six hundred and something with no problems but thats with stock pipe too and the same plugs are in it.
Sent from my C771
1 - 20 of 183 Posts
