21 - 40 of 46 Posts
Discussion Starter #21
Progress report:
Took the whole front right apart, I'm doing one side at a time start to finish. This way I won't lose any bolts, misplace any parts, or forget anything.
First I'll start off with the boots, the front boots are EMPI-86-2453D and the rears are 86-2404D, props to JPS300 for the part numbers
That is what is included in the EMPI kit
Front's on the left, rears on the right
Front all apart
Clamp tools, the top one is for the EMPI clamps, the bottom is the Rhino Clamps (which I COULD NOT reuse BTW). They were too big for the empi boots, which means they are thinner rubber at the cup.
The EMPI boots feel much stronger, do not stretch nearly as much, and are a lot thicker at the ribs (which is where rhino's break)
Tool being used for rhino clamps
Repeat x 4 and then pound off the outer joint to get the boots off
This is my CV axle hammer, non marring
Put some more grease in there!
Rhino on the right, EMPI on the left
All done
I'll get some more work done tomorrow, but time has been really short!
Discussion Starter #23
Got some more work done!
Don't mind the axle angle, it's at full full droop just checking the boots. The way I had to do the boots was take off the inner bar clamp and let the boots go out more. They were too scrunched before, the clamp was hitting the rubber.
When I was doing the rear, I discovered a little problem...
There is a little metal tube inside of the rear trailing arm where the bearing goes, it is TOO SMALL for the trailing arm bolt. So I used a piece of all thread, it's fine..works great and it's the perfect size. Sure it's not AS strong, but I don't forsee any issues. No movement and it was actually tight even before I torqued it down.
I left the clamps off the rear until I get the ride height figured out!
Discussion Starter #24
The other day all my stuff from powder coat got done (this was the hold up!)
Did work today! No issues what-so-ever. Not gonna need the 2" wheel spacers
Still have a ton to do including adjusting the suspension but everything fit and it's off jack stands, which was the goal for today!
Discussion Starter #26
Its powder coat. It will eventually chip off but I'm not too worried
Should be wrenching instead of using Tapatalk...
If it ever chips off you could put that rubberized bed liner on it. That would hold up a little better than paint. Looks sick though. Wish I could afford to build something like that.
How much GC do you have with the lift and those tires? Also how much clearance between the tires and rear of the floorboards?
I am going to lift mine. I dunno if I want a 4" or 6" because I want to be able to crank my shocks back down a little for it to ride smoother but I still want to be able to clear 32's.
Sent from my XT926 using Tapatalk
Discussion Starter #29
Haven't adjusted my shocks yet so haven't measured. I will be working on it tomorrow though.
I had the 6" on my gade and I hated how the boots rubbed on the front. I turned it down to like a 4.5 or 5".
The 4" is perfect, I would go for it again without hesitation. 32's will fit even with a bracket lift and extended trailing arms!
Discussion Starter #30
Finished the bike a few weeks ago
I broke both rear shocks on the first ride! NO good, getting commander shocks
I have commander shocks on the way!
wow that a hell of a build... so did you ever put the compressor back in or just say fuggit? also, did you make those audio tubes yourself?
Looks great J!
Posted via TapaTalk for iPhone5
Discussion Starter #34
I just ripped everything air related off! IT's garbrage, it really shouldn't be on an atv/sxs
I made them myself yup! I might have forgot the pics in this thread but they are on can-am forum. I'll dig them up!
Discussion Starter #37
One is fan override the other is led light bar !!!
Awesome looking bike mayne. Thing looks mean. Is it just the picture or is the XMR like 2 feet longer than a brute? lol
can you post a picture of the front view of your audiotubes? also how did you make that cut?
21 - 40 of 46 Posts
