1 - 3 of 3 Posts
Got a new kawasaki oem belt. Has stock secondary spring and either a maroon or red(its faded) primary spring. But on the shims i had 3, a thick a medium and thin.started with about 2" of slack. Tried the thick with the skinny then the medium. Now i have just the thick in and i have about 1.5"(38mm)slack.
Wasnt sure if the factory specs are still achieved with aftermarket primary. Should i get it within the 22-24mm?
Yes. Regardless of springs, you should still try to achieve the appropriate deflection.
  • Like
Reactions: Eryxian and Jrp79
Stay with orm belts only - all other belts suck on the kawie v twin. I set my belt deflection by how high the belt sits in the secondary sheaves or clutch. You should be around a 1/16” to 3/32 of belt cog showing above the sheaves
1 - 3 of 3 Posts
