1 - 7 of 7 Posts
Can’t seem to figure out what is wrong and wanted to explore options before paying an arm and leg for dealership to check it out. I purchased new, and the machine currently has about 60 hours on it. It was running fine the last time I rode it about 2 months ago. I got it out of the garage today and suddenly the machine won’t go faster than 30. It sounds as if it is stuck in low gear. No lights are on the dash and it is not stuck in 4x4. I have also already tried resetting the cvt and it did not change anything. Thanks in advance.
Super Moderator
Is there a specific way I should clean if I find something inside?
If it's blood and guts from mice, water with high pressure. If oil from a leaking seal or line, pull the clutches and clean with spray brakeklean and fix the problem. If oil the belt is most likely shot now so a new one is in order. But pull the cover first. It's only the first place to look.
Discussion Starter · #6 ·
There is nothing in the belt cover.. I am going to replace the belt while I have it off but it looks fairly new.. I mean only 60 hours on it. Any other recommendations
1 - 7 of 7 Posts
