1 - 8 of 8 Posts
I have a question about my four wheel drive. I will click into 4 wheel, the front will engage and randomly it will come out of 4 wheel. I don't know why that is. Any ideas? Also I don't one if it is normal, when I choose 4 wheel the 4wd light flashes between 4 and 2. I dnt know if it's supposed to stay on one.
It sounds like your 4wd actuator is shot. That flashing between 4wd and 2wd is a code to let you know the actuator is bad. IIRC .5 sec interval is 4wd, 1 sec interval is KEBC actuator, 1.5 or 2(i can't remember) is both actuators.
its 2 seconds. u are correct. those are the intervals for the respective problems.
you know, you can remove the actuator and clean it often with good results.
Clean and lube the inside.
on right side of bike look inside front tire on the front diff. black unit right on the side.
a little you will have to top it off
if you do, it only holds less than half a quart - 0.42 quarts (you should overfill it though)
1 - 8 of 8 Posts
