Well I cleaned my switch which was dirty. But still no 4x4. What to check nextI am also having problem. Switch to 4wd and nothing no flashes just stays in 2wd. I tested the actuator with 12v. Before I reinstalled it I plugged it back up turned on the key off and back on and the actuator reset. Should I look at the switch or something else.
I think the first thing to check is if the actuator is moving. Do you know how to do that?I have a 2010 750i it goes into 4x4 bit in the dash it stays in two wheel drive what could be the problem
I'm in the same boat. I tested the switch and I'm only getting about 2.5v to the switch. Going to dig in, clean and grease all electrical connections. Sent Rmax a text. Won't let me send PM yet.I am also having problem. Switch to 4wd and nothing no flashes just stays in 2wd. I tested the actuator with 12v. Before I reinstalled it I plugged it back up turned on the key off and back on and the actuator reset. Should I look at the switch or something else.
Not sure if he has a link but you can PM him, here is his page MudInMyBlood Forums - View Profile: rmaxCan someone post a link to the rmax manual 4wd kit
Jason, not sure how to check the black box but before you ride it off a cliff this is a Sure fix here!My brute will not go in 4wheel drive my lights r not flashing my 2x4 switch is good I check the front actuator works when I apply 12volt to it I've put the pin in 12oclock turn power on a got it to 2or3 miles per hour an it goes out of 4 wheel but will not go back in I've checked the relays by the rollover the buss mod is done only thing I can think of in the black box is there a way to check it with a meter please help bout to ride this thing of a cliff
